th350 and 4.11 gears??TALK ABOUT highway rpm ??
Old Apr 10, 2002 | 05:50 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
MAN......I DONT HAVE my tach hooked up right now(changing from led, wich the previous owner put in to real tach) but i drove my car out and i guess i got to about 55(my speedo is like 40mph off because of gears)and the rpm was skyrocketing.........is this ok......to drive my car near the 3000 or 4000.. rpm.. i'm not sure what rpm it was.......
actually it was kinda cool..besides the high rpm...
cant get any traction though...
Rob.....
so i guess i'm saying ..what is an ok rpm range for thruway driving ??
Old Apr 10, 2002 | 07:04 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Assuming you have a 13" radius tire, that puts you at 3186 rpm at 60 mph.
Yeah that's wheelin...at 70mph you're at 3717 rpm!!!!
It's fine if your engine is setup for it. You might want to use a thicker oil, or change it more often, but all the old school cars ran at like 3000 rpm on the hiway.
Old Apr 10, 2002 | 07:51 PM
Car: 1983 Z28 Clone
Transmission: TH350
thanx...i'm getting the oil changed tomarrow.......and quite frequently after than then.......
thanx..
rob
Old Apr 10, 2002 | 10:11 PM
xxwarrior36xx's Avatar
My buddy has the exact same setup as you he had a 350 and a 4:10m and blew his engine on the highway...watch yourself. Just a word of warning. Got to www.smokemup.com and get your tire diameter and figure out your rpm its a great site. I might buy a car with similar......76mph is 4000 rpm
Old Apr 10, 2002 | 10:22 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You might want to get a starter heat shield as well, cruising at those rpms is going to heat things up.
Old Apr 10, 2002 | 11:31 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: th350 and 4.11 gears??TALK ABOUT highway rpm ??
Rob.....
BOY, that's going to be spinning pretty good. You're probably going to need at least a well balanced rotating assy, and GOOD rods to crank up that high for prolonged periods. If you can stand to drive it 60 mph, should be ok. But I wouln't go much beyond that. If you're planning on doing a lot of state driving, your better off with a 700 or 5, 6 speed. Just my 02. If it were mine 3500 would be max, for long term travel.
Old Apr 10, 2002 | 11:41 PM
Car: 99 Formula
Axle/Gears: 342
Re: Re: th350 and 4.11 gears??TALK ABOUT highway rpm ??
I don't like driving above 2500rpms for a long time.. Just my preference.
Old Apr 11, 2002 | 12:26 PM
Greg Kuhlmann's Avatar
geeze... mine on the highway does about 1700 to 1800... but then again i have some retarded 2.73's
Old Apr 11, 2002 | 01:52 PM
Stroked-Z's Avatar
'81 Z-28 here....
I have 4:10 & HAD A TH-350....
Well i am getting a 700R4 built...
Revs are too high, gas is too expensive & you cant drive it on a long trip without OD.....at least I wouldn't, and won't.
Old Apr 11, 2002 | 03:11 PM
Car: 1983 Z28 Clone
Transmission: TH350
well its only going to be on fridays...... about 10 miles to the track and 10 back........hey if i blow it up.... its 350 time!!!!
but seriously.. i appreciate it ...i feel i'm not alone now..but...its not going to be an everyday thing..... just to get to the track and back...
Rob......
Old Apr 11, 2002 | 03:57 PM
Fast3rdGen's Avatar
i got a th400 and the 9" i am puttin in soon has 4.33's. i got 26" tall tires as well. but my car hasn't seen highway since the 3speed went in anyways.
Old Apr 11, 2002 | 04:27 PM
Car: 1983 Z28 Clone
Transmission: TH350
dayam........4.33.....pretty cool.. i want to get some bigger tires...right now i got 14's.....but not sure what tire size...they are dinkey..though.............
its nice though..because its like artificial horsepower....can burn the tires with no effort............................................its cool...but.. not cool because i have no traction....
Robio
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
Dialed_In
Aug 20, 2015 01:45 PM
jbd1969
Aug 17, 2015 07:06 PM
