why B&M shift kits won't shift from 2-3 and has high 1-2 shift
Old Apr 11, 2002 | 11:32 AM
benjob's Avatar
i installed a b&m shift kit. and it didn't shift from 2-3 and the 1-2 shift was super high. so the problem is that in the directions for b&m they leave out the 2-3 piston pin wear the spring used to hold the piston in place. with the little spacers they give you won't hold the piston and on top of the fluid will just flow right through them ( which is not suppose to happen) so you can order the little piston pin witch is about 1/4" diameter and 3-4" long. iam sure you know what iam talking about because you have one for the other piston in the valve body but not one for the one in the tranny. If you have any questions about this email me
b0horman@wmich.edu
thankx
ben
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
