axles??
Old Apr 12, 2002 | 12:37 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
axles??
how hard would it be to change the drivers side axle out of a 92 RS, when i bought the car it was washed down in a flood and evidently the back drivers side wheel hit a curb and warped it slightly
Old Apr 12, 2002 | 07:34 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Jack it up, remove wheel and brake drum. Remove the diff cover, drain fluid. Push axle inward slightly and remove C-clip when it falls out. Pull axle out. I'd replace the seal and reinstall the new axle. Assembly is reverse of removal.
Aw hell...put an SLP posi in it while you're in there!!!
I think that's it unless I forgot something.
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
