TPI throtle body on a 3.1 MPFI?
Old May 8, 2002 | 07:13 AM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
can i put a tpi throtle body on my 3.1 mpfi?
Old May 8, 2002 | 09:42 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Not without a custom made plenum.
Old May 8, 2002 | 09:58 AM
kvu's Avatar
kvu
yes you can.Just get a thick plate of metal/alloy and on one side drill and tap for the l98 tb.Make the backside of the plate mate the v6 plunum.Then make a smooth transition for the air to move from the l98 tb to your plunum.
Old May 8, 2002 | 09:59 AM
KED85's Avatar
You'll get better gains on performance by selection of other means for increased performance.
Old May 8, 2002 | 01:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow, Karl, that sounded like it came from a college textbook! And I agree w/Karl!
Old May 8, 2002 | 03:29 PM
89camaroRSV6's Avatar
if ur gonnna go thru all the trouble ..to ptu a tpi Tbody...
u might as well try to remake the upper plenum...ive seen it done on a fiero before..
he used 2 2.8 Tbodys with a custom made upper plenum and connected one TB to the other mechanically...
i dont remember where i saw it but it was on a fiero forum....
all the electrical connectors were on one TB whereas all that the other did was duplicate teh one that was open...im not soo sure about the injectors he used 'cos definitely it needs more fuel...
Old May 9, 2002 | 09:30 AM
KED85's Avatar
Tom, you are TOO KIND!
I read some of these ideas,
Don't many here just want to drive their cars instead of reinventing the wheel?
About the only place may of these "modified ides" may end up...
is some computer graphic created image...
Cheapest easiest way to create some ideas.
Like the car show curcuit....
All chrome & show, no go.
Old May 10, 2002 | 11:46 AM
kvu's Avatar
kvu
Hey I just said it could be done but I did'nt say it would make power.:lala:
Old May 10, 2002 | 12:15 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
here's a link to one of those modified intakes. It's for a 3.4, but still can be done:Tiago
Old May 10, 2002 | 01:50 PM
BitchinRS's Avatar
Unfortunetly he never showed a completed picture of the engine. At the end it still did not have the intake on. Or did I miss a pic?
Old May 10, 2002 | 01:56 PM
his dyno shows something like 156hp...after a all those mods...am i missing something there????
its seems not much gain for a 4th gen bird???after all the stuff he has in...or is it the dyno before all the stuff..
Old May 10, 2002 | 03:52 PM
Engine: 5.7 / 7.4
here's the link to the main page Tiago 2
on the link for the dyno run, he lists what mods, or lack of ws run for it.
Old May 10, 2002 | 11:14 PM
87 Firebird's Avatar
I dunno what that car was at stock, but that figure is REAR wheel hp, not block hp, as in our cars. Our 135 bhp is more like 115 rwhp or less when you figure in accessory losses, friction due to drivetrain, etc., etc.
Old May 11, 2002 | 06:17 AM
Engine: 5.7 / 7.4
the stock 3.4 motors were rated @ 160hp & 200tq
Old May 11, 2002 | 11:00 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Damn, Dan..you're like..my twin. Except your paint isn't missing chips here and there. And your ground fx aren't scratched to holy hell on the bottoms.
BTW: Thats an old pic...the grille is now uniform flat black...thank ***.
Old May 13, 2002 | 07:04 AM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
actualy my car is teal the picture is just messed up from being scaned and it turned out blue.
i just had a guy repaint my car a year ago and it is chipping on the front and the back.
Old May 13, 2002 | 09:48 AM
kvu's Avatar
kvu
My paint sucks too,at least I have a 400sbc in my car.Really though the best way to mod a v6 is to get a super/turbo charger.If you build it right then it could withstand enogh boost to roach a viper easy.The thing is things like pistons are priced per 1.You will have less cost vs a v8,so you can do a bit more for the same money.I do have a 87 v6 camaro and might end up getting a turbo from the boneyard.I make my own chips so I would just virtually need to make the exhaust.
Old May 13, 2002 | 05:00 PM
Nixon1's Avatar
True, turbos are real effective for power in V-6's...but I mean, it'd be all custom. No turbo kits for our cars. And you know how custom machining is...$$$. Plus, turbos aren't something to play with in your spare time. You screw up a turbo setup and you can say bye bye to your engine in no time flat.
Old May 13, 2002 | 10:39 PM
kvu's Avatar
kvu
But if it was done it would be one badd @ss v6.The 89 turbo t/a could be used as a blueprint.
Old May 15, 2002 | 06:34 AM
Nixon1's Avatar
Yeah, it would. If I had the money, I WOULD have a turbo custom setup for my 91 RS. Just to surprise the HELL out of the IROC boys and the downtown ricers. BUT, I'm pretty much broke. Guy's gotta have a dream....
Old May 15, 2002 | 09:40 AM
KED85's Avatar
Dream of a WOMAN
Old May 16, 2002 | 04:36 PM
Nixon1's Avatar
Hmm....good idea, KED... Ever seen that Midas commercial with the guy in the hot tub?
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
the_nikfive
Aug 11, 2015 02:46 AM
