Gauge needles bounce when turn signal is on
Old May 10, 2002 | 01:08 AM
Akshay's Avatar
When I turn on the turn-signal, all the gauge needles start bouncing (up and down, up and down). When I turn off the turn-signal, the needles return to their previous positions.
Akshay
1989 2.8L Camaro
Old May 10, 2002 | 01:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I wonder about the condition of your battery (is it nearing the 5-year "death" mark?) and alternator (check voltage of battery with car off, should be 12 volts, remove the meter, start the motor, check voltage with engine running, should be 13.8ish volts).
Old May 10, 2002 | 01:52 PM
Akshay's Avatar
The battery is fine. My headlights don't dim or anything, but I will check the alternator, though.
Akshay
Old May 10, 2002 | 09:16 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
my turn signals do the same. Battery is new and alternator passes all checks... I don't let it bother me...
Old May 10, 2002 | 11:55 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
check your grounds, loose/chaffing wiring.
Old May 11, 2002 | 09:22 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
What the he!! is loose/chaffing wiring???
Old May 11, 2002 | 10:58 PM
Engine: 5.7 / 7.4
loose wiring: not tight, coming loose, also applies to connectors
chaffing: as in new corderoys, the inside of legs rubbed raw
wiring: lots of wires
loose conectors/wires, some wires getting the insulation rubbed off & shorting
Old May 12, 2002 | 08:02 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Old May 12, 2002 | 10:48 AM
WaynesRS's Avatar
I think this is pretty normal . My car has been doing this sence I got it in 95 .The only gauge that does not bounce when the blinker is on is my speedometer .
Old May 12, 2002 | 08:00 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
same here
Old May 12, 2002 | 09:51 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I had similiar problems last tuesday night after graduation. I turn my lights on and theres only one light on around my speedo and all gauges jump around when I signial, so I drive it to the store a block away and take my gauge cluster out and look at my connecters that go into the cluster and they were fine. Then I looked at the back of my cluster and saw some of the circuit ends"or whatever they are called" were touching each other and straightned them out and the prob was fixed.I hope that helped sorta.
Old May 13, 2002 | 12:42 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
What did you graduate, HS or college? Congradualtions. One month and 7 days until I grauate HS, whoohoo!
Old May 13, 2002 | 12:51 PM
Car: 85 Camaro SC
Engine: V6
HS, and the 15th I will finish up my first semester of collage. When did your school start cause 5 weeks is alot compared to the schools around here.
Old May 13, 2002 | 12:52 PM
WaynesRS's Avatar
Congrats to both of you
Old May 13, 2002 | 02:09 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
we started like in the middle of september, this couty sucks, Congrats on the semester thing, thats great.
Old May 13, 2002 | 04:42 PM
Camar_Hunter_c's Avatar
well I got a higher output amp and my needle stays pretty steady. 160 AMP alt for $189?.. I think. GREAT BUY. I highly recomend it. Even if stock, I would serioulsy go to 140 AMP. You WILL notice the difference in charging and your lights being brighter.
Old May 13, 2002 | 10:13 PM
Car: 85 Camaro SC
Engine: V6
September I started 15th of august. I have a 150 amp alt in my car. My gas guage is the only needle that will bounce, the funny thing is I believe the problem lies in the guage its self. The reason why is when I use to have the starwars gauge cluser with the tach size gas guage the needle stayed steady no matter what. But with the smaller one every time I hit a medium bump the needle bounces, so I'd say its gotta be the gauge.
Old May 14, 2002 | 08:13 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
i still have the stock alt. that could be the problem, i'll just wait till it goes, with the things that are going on now, it propally won't be long.
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
