can i make this turbo work on my 3.1
Old May 29, 2002 | 09:40 PM
ice775899's Avatar
i have a turbo from a 2nd gen carburated turbo trans-am and my car is fuel injected and i was wondering if there was anyway to make it work without damaging my engine
Old May 29, 2002 | 10:43 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
well, first of all welcome to the board. second of all yes you can make it work. and third of all, the only way it's going to work is if you have megga dollars to spend on it. A turbo setup on a 3.1L v6 will require a completely different setup than the one that you have for the old TAT, and all your work would have to be customed fabbed being that there is no turbo setup designed for a rear wheel drive 60 degree engine yet. there's a few folks on here who had mentioned turbo fever, nothing's been acomplished yet, and yes they all have turbos, but they'er still not on the engine. hmmmm, good luck with whatever u try to do.
Old May 30, 2002 | 02:31 AM
KED85's Avatar
It's easier
to install your turbo
by scanning it on to your computer
and computer generating your dream turbo installation on these 60* V-6 without damage to the engine.
Welcome,
Try another idea for power.
You CAN grab that turbo, tho.
DOES IT HAVE A PONTIAC PART NUMBER ON IT?
Sell it on ebay
Be honest and invest your time in the GM Performance Parts book (Measly $6 any GM dealer).
Read what GM has to offer us & the 60* V-6.
Set your realistic goals and budget and who has the tools and spare car to drive.
Ask me about swapping in 3.4's!
Old May 30, 2002 | 10:03 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
do you have the intake mount alomg with the turbo, if not, I know a certain someone (me) with a certain 76 bonnieville w/a 400 (me) that might be able to use the turbo intake
Old May 31, 2002 | 02:10 PM
ice775899's Avatar
yes the intake is on it too it came of in one piece just no header wastegate was taken with it. as far as i know it came off a 400 block too.
Terrell351
Jun 13, 2021 01:13 PM
mustangman65_79
Aug 11, 2015 03:17 PM
the_nikfive
Aug 11, 2015 02:46 AM
Fronzizzle
Aug 9, 2015 01:15 PM
guy76767
Aug 6, 2015 05:58 PM
