Poor Fuel Economy: Time for a tuneup?
Old Jun 3, 2002 | 03:56 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I was talking to somebody about my car because they liked it, and I told them it was a V6 automatic. He said, well, on the plus side, you must get good gas mileage. I told him 180 to a tank max, he said something must be up. The car is a little sluggish when going up hills (A PLYMOUTH RELIANT KEPT UP WITH ME!!!!!!!!!!!!!!!!!!). I figured I'd put two and two together and I figured I must need a tuneup. How much gas mileage to a whole tank (15 gallons) do you 3.1er's (auto) get? My car is almost at 66,000 miles. It runs great, but it does tend to be on the slow side, yes I do know it is a V6 and these are 4000 pound cars. Do you guys think it is time for a tuneup? P.S. This whole plymouth reliant deely is Pis*ing me OFF!!!!
Old Jun 3, 2002 | 05:25 PM
Eric-91Camaro's Avatar
When was the last time you got your car a nice, fat tune up ?
after market spark plug wires, spark plug, dist. cap and rotor , etc ...
Click 'search' on the top right of your screen and do a search for TomP's 'major tuneup'
P.S. I get around 24 mpg.
Old Jun 3, 2002 | 06:36 PM
Thanks a lot eric! My car gets 180 on driving through light traffic. Guess my car does need some major work. I dont really know the last time it got tuned up, probably never. I have had it for a year and a half just sittin around till I recently got my license, before hand it is bone stock. Only things changed were probably the things needed to be changed, as the previous owner was a female. Guess its time to break out the wallet for this one
Old Jun 3, 2002 | 08:48 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Well at least it wasnt as bad as the first week I drove my 85, I got 100 miles on 11.7 gal I was running wwwwaaaaayyyyyyy rich, then after a new o2 sensor I got 203 on 9.1 gal, and last week I got a new egr valve and I went 250ish miles on 9.7 gallons. Right I've gone 100 miles in only a 1/4 tank so I still have 1/2 a tank to go until I gas up "I never go below 1/4 tank". So a tune up is really needed for your car.
Old Jun 3, 2002 | 09:17 PM
Thanks 85sportcoupeto89RS. I guess I need those items as well. Dude, this is gonna be pretty expensive, but in the long run I guess it will keep other parts from straining and failing also. I am assuming that a bad 02 sensor will not make the check engine light go on. How much do they cost? Nice conversion by the way, u did a good job!
Old Jun 3, 2002 | 09:57 PM
Car: 85 Camaro SC
Engine: V6
I got my egr for 30 bux. And my o2 was 12 bux. I estimate you'll spend around 250.00 for everything you need. New plugs and wires, egr, o2, distrubitor cap, check the timming, change oil and fuel filter"when I replaced mine it weighed almost 2 1/2 pounds check your belts for any frays or needing to be tightned. Thanks I have almost 175 Hrs of restoring on the body,motor and int.But its worth it.
Old Jun 3, 2002 | 10:15 PM
WaynesRS's Avatar
Could just need a fuel filter , could just need some new plugwires ...BUT , if it has not had a tune-up in awhile . I suggest doing TomP's good ole' tune-up !!! If money is tight , you can do things like :
1. go out at night , and see if you see and plugwires or your coil arcing out , (you'll see a blue glow )
2. change your fuel filter , its cheap , it might run a whole lot better just after that !
3.check your air filters , (are they paper and real dirty ? ) If so get some K&N's . If you already have K&N's get a re-charger kit and clean them !
4.take your distributor cap off and check it out , are the terminals real ate up , is there alot of carbon ?
BUT ; if you want to go ahead and do a full tune-up . That's what I suggest , if you have not had it in awhile , do TomP's tuneup . Do a search on here in the search and you'll find it !
Old Jun 4, 2002 | 02:00 PM
okay sounds good, although the mechanic did check all that stuff during inspection, wouldn't hurt to check again tho
Old Jun 4, 2002 | 08:43 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
It probably wouldnt hurt ya to look at my "Help car is running like crap" topic.
Old Jun 4, 2002 | 11:48 PM
KED85's Avatar
Plan on changing the timing chain soon, too.
Also rebuild your distributor, too.
Yeah, empty wallet, but, if you really like the car, one project at a time will help the budget
By Levittown?
Went to Bucks County Community College.
Lived in Schwenksville & Hilltown.
EAT A PATS CHEESESTEAK FOR ME!!!!!!!!
Have some Tasty Kakes for me, too!!!
Old Jun 5, 2002 | 08:41 AM
Yeah I am near Bucks County, I am from delaware county. Tastycakes are awesome, as for cheese steaks, I am up for them, minus the cheese. As for the car, what is required to change the timing chain?
Old Jun 5, 2002 | 09:10 AM
KED85's Avatar
It's an involved mission.
Remove pulleys at crank
Remove balancer
Remove timing cover water pump assembly, replace chain.
NOT SIMPLE
BUT
if your engine is a non smoker non oil burner, consider the effort for the solid gain.
IT's not just HP you bring back to car, but, smoother stronger power.
It's a very simple foundation item ya need to really consider.
Go to the yard & check any engine with the timing chain cover off it.
Feel that chian.
That's your chain. Loose & outta synch.
Also your distributor is worn down and could use a fresh rebuild too.
That's an easy job, do the search that topic.
I recommended someone to Northern Auto (800-831-0884) They said their prices went way higher!
Try others. OR call them and tell them to lower price or other vendor will get your busine$$.
You only need a new chain, not a fancy name,
timing chian set, timing chain gasket change kit, WATER PUMP (it's in your hands! change it).
It's a mission, but do this ONLY on good sealed block, not a leaker or old age block.
Really will make your engine feel great again!
Old Jun 5, 2002 | 03:11 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
What about the coils? It's time for new coils?
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
