ATTN. TomP
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ATTN. TomP
hey man
i just bought a posi/disc/3.23 rear from a 94 Z28
i picked it up last nite
heres my questions:
besides the proportioning valve, what else do i need to change to get the brakes and parking brake to work correctly
it came complete with rotors and calipers
i heard i need to change a few things, but i'm unsure of which
thanx
heres my questions:
thanx
Car: 1986 Firebird
Engine: 2.8 V6
Not too sure about the 4th gen rear; you could ask over at camaroz28.com 's V6 area. But as for hydraulics, I've heard the same thing; you just need the prop valve. You might want to start spraying down the rear brake axle-hose-to-body-hard-line connection now with Liquid Wrench. Also, you should replace your 11 year old body-to-axle hose. If you have an extra $100 lying around, check out http://www.brakebleeder.com - I bought it, and it almost makes bleeding fun!
Tom, I thought you had a 4th gen rear in your bird?the 4th gen rear is actually going into my Z28
my V6 RS is now officially my beater
Car: 1986 Firebird
Engine: 2.8 V6
No, I put a 3.73/posi/disc axle from an '84 Trans Am into my car.
Then the posi blew, and now I'm on a $100 '88 V6 camaro's rear axle for the time being.
Car: 1986 Firebird
Engine: 2.8 V6
That's alright, just let us know how your project goes! I'm sure plenty of guys here would be interested in that swap- especially after the hell I went through with my rear discs, before I found out about the $60 recall kit to fix 'em. (82-88 rear discs were recalled.)
thanx tom
i need to figure out a way for someone to weld a pipe for EGR and a bungnut for an 02 sensor into my V6 headers
i'm probably going to put those on soon, once i get my Z28 on the road
where have you been.......?
they used to make headers a while ago for the 3rd gen V6 f-bodies.......
every once in a while a set pops up on ebay
i got a set that was never used before and are brand new
they are not setup for EGR nor an 02 sensor though
87_Camaro
Aug 29, 2001 04:41 PM
