Supercharger pics
Old Jun 16, 2002 | 08:04 PM
I Cant Drive 55's Avatar
Supercharger pics
This is the supercharger I plan on trying to put on my 89 2.8 firebird.
I have to make a mounting bracket to put it where the smog pump would usually go. I also have to change the pulley over to a serpentine belt pulley . I plan on using the existing airbox and put an adapter on the charger so I can run a hose to the airbox.
My question is should I put the MAF sensor on the output side of the charger or on the inlet side.
I probably wont start on this project for a few weeks , but any input of ideas would be great.
Old Jun 16, 2002 | 08:05 PM
another
Old Jun 16, 2002 | 08:07 PM
and another
Old Jun 16, 2002 | 08:25 PM
Camar_Hunter_c's Avatar
woo thats an oldie...
The MAF goes on the intlet side, the outpit PSI would explode the plastic.
Old Jun 16, 2002 | 08:42 PM
Yeah my father got it in the early 80s . He put it on his ford pickup to try it . He says it made too much noise and the carb. needed to be rejetted for it. He had the hose running to his factory air cleaner and the turbines exposed , I think thats why it was so noisy. It has been shelved ever since,thats why its so dirty. I think it will work well with the MPFI because the Computer should compensate for the changes.
Thanks for the info on the MAF.
Old Jun 16, 2002 | 09:14 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
probably gonna need to do some ECM tuning afterwards.........
lemme know how it goes
good luck
Old Jun 16, 2002 | 11:45 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Damn, and I thought my turbo was old/rough shape. Makes mine look almost new
My Turbo
careful, one of those slow pics for dial up
Old Jun 17, 2002 | 09:32 AM
WaynesRS's Avatar
DOOD !!! THATS AWESOME . I can't wait to see how it turns out .
Old Jun 29, 2002 | 11:50 PM
mrzud's Avatar
Good luck. Tell us about it while doing it.
Old Jun 29, 2002 | 11:56 PM
WaynesRS's Avatar
How did he like it on his truck besides being to noisey ? And what kinda car did it come off of ?
Old Jun 30, 2002 | 12:52 AM
89camaroRSV6's Avatar
depends on how much psi ur gonna make outta that one..
id say go for atleast 19lb/hr injectors and a fuel pressure regulator u won regret it ...
and i strongly suggest if ur gonna use that thing go for a toothed belt ..that serpentine or v belt thats gonna use is gonna slip @ some point ....well im still trying to put a honda waterpump toothed pulley on camaro_hunters supercharger shaft ..lookin @ some machine shops here but most of them are either ridiculously expensive or downright stupid (know nothing about what im asking)
(mayeb ill end up machining another shaft where the pulley goes in ..)
(tip : honda accord waterpump pulley and cam shaft pulley (maybe 2 camshaft pulleys) might be a good starting pioint)
in ur case first try the v belt since it already has the pulley for it
Old Jun 30, 2002 | 09:49 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
<----- Anxiously waiting for results
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
-=Z28=-
Sep 24, 2015 10:21 AM
gt4373
Sep 9, 2015 10:29 AM
