got problems again
Old Jun 20, 2002 | 04:52 PM
87Bandit's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8lt V6
Transmission: TH700R4
got problems again
i just got a new oxygen sensor and a new fuel filter put on. The others were originals and i thought after 76000 miles it was time to put new on. But now it seems that when i accelerate the car hesitates and sputters until above 2500 rpms. Can anybody help me here. I am clueless. My dad thinks that it may be bad gas, since i did just fill up my tank.
Old Jun 20, 2002 | 07:04 PM
WaynesRS's Avatar
It could be bad gas sence you just filled up the tank . Have your plugwires ever been changed ? What about your sparkplugs .
Old Jun 20, 2002 | 07:29 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hmmmm
could be many things
what comes to mind right now: fuel pressure regulator, MAP sensor, dirty injectors
i think we could rule out the bad injectors though, because then the engine would run like crap all the time
i BET its your TPS
Old Jun 20, 2002 | 10:17 PM
KED85's Avatar
Vacuum
Driver side by base of distributor is the main problem one.
Old Jun 21, 2002 | 12:40 AM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
karl, you beat me to it
Old Jun 21, 2002 | 02:24 AM
laegion's Avatar
Car: 84 Trans Am Ws6
Engine: 305 LG4 "H.O."
Transmission: wc t-5
have you tried resetting the ecm since you replaced the parts? it's really simple but it can cause alot of problems.
Old Jun 21, 2002 | 03:21 PM
87Bandit's Avatar
Engine: 2.8lt V6
i already reset my ecm. When i did i unhooked the battery, then when i hooked it back up 5 minutes later, the car would not start. I sooned realized that my battery was completely dead. I took it to the parts store and had them test it and she said that it was lucky to last this long since it was bought in April 1994. Also i have an amplifier hooked up to my subwoofer, and that didnt kill the battery before this. I still have no idea whats wrong. Im hoping that its just bad gas, im going to try putting in octane booster and see if that works.
Old Jun 21, 2002 | 04:29 PM
KED85's Avatar
Me
Seriously.
I think you have LOTS of little problems compounding and causing all sorts of troubles.
You must get back to square one & go forward again.
Lots of hunting for your small problems.
Old Jun 21, 2002 | 04:35 PM
KED85's Avatar
Sorry goofed
Old Jun 21, 2002 | 09:36 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
little problems....
i had those, ghot them all fixed now
don't get too overwelmed, you solve the problem and get it fixed, just give it time.
Old Jun 22, 2002 | 08:01 AM
laegion's Avatar
when you first started the car after you hooked up the battery did you let it idle for 5 min, then drive for 15 or so till learn mode turned off?
Old Jun 22, 2002 | 02:14 PM
87Bandit's Avatar
Engine: 2.8lt V6
yeah, i let it idle, but i didnt drive it for 15 minutes. I just moved it into the garage for the night. I have been driving it this week and the hesitation is still there, ,but is slowly goin away, im goin to check that vacuum line by the distributer though.
Old Jun 22, 2002 | 04:50 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Sounds like an EGR valve stuck open. How is the idle quality?
You didn't put the fuel filter on backwards, did you?
Old Jun 23, 2002 | 07:58 AM
87Bandit's Avatar
Engine: 2.8lt V6
i didnt put the fuel filter in backwards, i triple checked. The idle is not real bad until the car is totally warmed up. It kind of bounces on occasion when the a/c is on, but other than that it is okay.
Old Jun 23, 2002 | 09:44 AM
KED85's Avatar
During my swap, I spent one whole day rebuilding the vacuum hose system.
A year later, I had to separte the upper intake to get better access for new worn hose sections.
Including that back hose by distb.
It's a hunt for all leaks, but, can solve lots of problems given through effort.
Honest.
ESPECIALLY underside by EGR & manifold!
Can you say "surprise"
Lots of hoses can collaspe during vehicle operation under load, due to old age.
5/16" windshield wiper hose is the magic number
That back hose is a short section 1/2" heater hose, with lots of oil, to slip fit on.
Oh the joy of replacing that hose!!!with engine in car!
Old Jun 23, 2002 | 11:28 PM
WaynesRS's Avatar
You will be surprised to how the car has more "pep" in it !!! The job is WELL worth it . It also made my car run quieter , which is a good with with a gutted cat !
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
