suspension for a V6?
Old Jul 5, 2002 | 07:31 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
does anyone know of any manufacturer that makes lowering springs for our cars? hotkchis makes a performace kit that lowers the v8 cars one inch but they won't work on the v6's, supposedly, any help would be appriciated
oh, and any other suggestions to make my car handle better on the turns would be helpful
Old Jul 5, 2002 | 08:04 PM
Camar_Hunter_c's Avatar
Best thing you can do is ger Iroc Sways Front AND Rear, and rebuild suspension with Polybushings. Hell i am still running around on rubber factory junk and I can turn on a dime. I also have Iroc Sways. The rear 'Roc sway is the Front RS diameter. Seriously. The front is almost twice the thickness it seems.
Old Jul 6, 2002 | 12:39 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
not sure on how it will handle, but get springs for a 6 cyl, manual tranny, no a/c. those things are a good 5-7 inches shorter than one for an auto w/air
Old Jul 6, 2002 | 12:49 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Mine handles fine with V8 springs...
Old Jul 6, 2002 | 12:19 PM
my91rs's Avatar
Car: 91 RS
Engine: 3.4L
suspension tech. makes springs for our car. Or you could get spindles for the front and V8 springs for the rear.
Old Jul 6, 2002 | 05:48 PM
Johnny Ray's Avatar
5-7 inches shorter?!!!????
Damn!
What diameter of tires are you running what your car lowered that much?
Old Jul 8, 2002 | 10:41 AM
Makaveli's Avatar
http://www.lmperformance.com/C/1/18
hahaha i know the stuff comes cheaper if you shop around, but thats a lotta stuff
Old Jul 8, 2002 | 01:14 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
These are the best right here:
http://www.LMPerformance.com/1847/18.html
Old Jul 8, 2002 | 02:00 PM
mw66nova's Avatar
Engine: 7.0L
thanks for all of the help guys
Old Jul 8, 2002 | 03:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Rebuild the front suspension with all new bushings; and for the most performance, use a polygraphite or polyurethane rebuild kit. Also, the center link and idler arm are common "wear items" on our cars; meaning; they wear out faster than the other parts (like tie rod ends), so you should probably replace those too.
http://www.p-s-t.com
http://www.energysuspension.com
http://www.performancesuspension.com
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
