will these lifters work or not?
Old Jul 23, 2002 | 09:01 PM
ice775899's Avatar
i have roller lifters from a 4.3 vortec engine and i wanted to know if they would work on my 3.1 or not. it'll save me the trouble of ripping appart the block to find out they won't work.
please help!
Old Jul 26, 2002 | 03:25 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
*no, but I might be interested in them for my blazer if I don't have them allready
edit: *-roller rockers we need are basically the same as in the ls1; narrow body rockers for centerbolt valve covers. if the 4.3 rockers are the same narrow body design, then they might fit.
Old Jul 28, 2002 | 10:45 AM
Bluerocket's Avatar
there is a part number for rollor lifters for 2.8 download the document in the post entited "how to build a super 2.8"
Old Jul 28, 2002 | 11:14 AM
AFrikinGoodTime's Avatar
Quote and pic from this article:
"The reliability of a v6/60 engine equipped with racing valve springs can be improved by installing 7/16-inch diameter big-block V8 rocker arm studs (PN 3921912). To perform this conversion on V6/60 cast iron heads, the stock studs must be removed and the 11mm rocker arm stud holes drilled and tapped with 7/16-14 threads. The rocker stud bosses will still have sufficient strength to support the larger 7/16" studs after they are re-tapped.
Enlagre the pushrod guideplate stud holes also. This can be done with a carbide drillbit to accomidate the larger 7/16" studs.
Aftermarket needle bearing rocker arms for a small-block V8 with 7/16" trunions should be installed on cast iron heads with converted 7/16" studs. Due to limited clearence between adjacent rockers, narrow aluminum rockers are required. Aftermarket rocker arms with 1.260" wide trunions areas are suitable (Crane PN 11756 or equivalent)."
The article does not state anything about valve cover clearence! I can tell you for certain that aluminim rockers arms will not fit on chevy V8 centerbolt stock valve covers. GM offers an adapter plate to convert centerbolt covers to the early design outside 4-bolt and also ads as a spacer. Our stock valve covers may work but I presently do not know this info and will check into it further.
EDIT: opps I just realised we were taking about lifters and not rockers. Sorry, my mind slipped off base when I read Project85's comment on rockers above. Roller lifters need to be used only with a roller cam. I have never heard of a roller cam for our cars.
Jake_92RS
Jan 28, 2020 10:37 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
drathaar907
Aug 6, 2015 04:20 PM
