2.8 to 3.8?? HELP?
Old Jul 31, 2002 | 02:41 PM
Camaro_1986_19's Avatar
2.8 to 3.8?? HELP?
Ok I have 2 things to do, Get me engine totally rebuilt for $700.00 or get a 3.8 out of a 1987 Chevy Malibu RWD for free.
Which should I do? And if I get the 3.8, What do I have to change?
Old Jul 31, 2002 | 02:47 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
https://www.thirdgen.org/newdesign/t...apboogie.shtml
Old Jul 31, 2002 | 03:19 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
The 3.8 will nto work without changing mounts.
Get a 3.4, or have that badboy rebuilt...
Old Jul 31, 2002 | 05:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
And the heads would need to be changed; the 3.8 engine won't fit between the f-body strut towers. I agree w/Stuart & KJ.
Old Aug 1, 2002 | 06:45 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Didn't I hear somewhere he could use the original 3.8 heads if he ditches the A/C?
Old Aug 1, 2002 | 08:41 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
No, too wide.. GM used special heads to put the 3.8 under the '89 turbo trans am. I think they're heads off of another GM motor, though.. it's in the thirdgen.org FAQ (off the tech area), I think in the Motor section.
Old Aug 2, 2002 | 06:40 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Yeah, I think they were heads off a LeSaber.
Old Aug 2, 2002 | 06:53 AM
So no go on the 3.8? And I should just get it rebuilt
Old Aug 2, 2002 | 11:59 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
What we're saying is that it CAN be done, but a 2.8 rebuild or 3.4 swap would be easier.
Old Aug 2, 2002 | 02:38 PM
89-28gp's Avatar
Car: 1986 Firebird
Engine: not stock 2.8
You'd need to get FWD heads from a 3.8 for it. It's more work to get this going then a V8 swap, I say go 3.4
Old Aug 2, 2002 | 06:50 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
flyin89 knows some people that used GN engine in their 3rd gens and kept the GN heads. They just had to ditch the AC.
Old Aug 2, 2002 | 11:06 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
exactly, you have to ditch the AC to use the GN heads, BUT THEY WILL FIT, i've seen it plenty of times
Old Aug 2, 2002 | 11:08 PM
fly89gta's Avatar
Car: 2018 Camaro SS
and yes the TTA heads are FWD LeSabre heads, much different than the GN heads, flow better from the factory but the GN heads have more meat on them, so if you were to fully port both sets the GN heads would flow a bit better..
Old Aug 7, 2002 | 11:28 AM
pontiacguy1's Avatar
This might be a Chevrolet 3.8 liter V-6 he is talking about. Not all 3.8s are Buick based. My mom used to have an '80 Malibu with a 3.8. It was a chevrolet, and had the distributor in the back. I think it is basically the same width as the small block Chevy V-8. The bell housing is the V-8 bellhousing,though, so you would have to swap the trans with the motor. I think it would work,though. You would need the motor mounts, accessory brackets, trans, and just about everything else from the donor car. If I remember, though, the 3.8 in my mom's Malibu wasn't very powerful, but it probably had 3.08 gears, and was breathing through a single exhaust and a 2bbl carb. It might be interesting to try and see what you can do with it.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
