missing a headlight anyone seen it?
Old Sep 3, 2002 | 04:59 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
i forgot to post this earlier but o well
.. i am missiing a headlight from the pass. side
its a low beam...
i noticed a tiny , but noticeable difference in my temp.
it usually goes up to about 225 or higher in stop N go traffic.. but after the traffic picked up and i cruised around 70 for about 5 - 10 mins,,.. well maybe not even that long the tem p went down fairly fast and was slightly lower then it normally is..
i am thinking about making something , like a pipe or hose to get air into the engine thru the hightbeam light instead cuz i never use them anyway.. any ideas please let me know thanx
Old Sep 3, 2002 | 08:24 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
Does your car have the little plastic spoiler attached to the bottom of the radiator? If not you can get one and that will really help. If you're just wanting it to run cooler, install like a 180* t-stat and maybe add a fan switch so that you could turn the fan on earlier. IMHO, I think that taking out the high beams and adding ducting to the radiator would look kinda funny, but that's just my $.02.
Old Sep 4, 2002 | 09:53 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Ever seen an older car? That's how they do their ram air systems.
Old Sep 4, 2002 | 07:06 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
I have seen older cars like that, however all of them had round headlights and they were all incorporated into the grill. To me it looked "less obvious" that there was a headlight missing. But if you want to do it, more power to ya! I just think that if you were gonna pull the high beams you might want to use that as a CAI/Ram air as opposed to aiding airflow to the radiator.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Sep 20, 2015 11:36 AM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
