Pics of the intake & tail lights
Old Oct 1, 2002 | 07:20 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
The "proposed" intake, and no Karl, I was thinking of this before you sent pics :nono:
http://www.thenebula.com/carpics/pics/34Intake2.jpg
http://www.thenebula.com/carpics/pics/34Intake3.jpg
http://www.thenebula.com/carpics/pics/34Intake5.jpg
http://www.thenebula.com/carpics/pics/34Intake6.jpg
http://www.thenebula.com/carpics/pic...l%20light1.jpg
http://www.thenebula.com/carpics/pic...l%20light2.jpg
Old Oct 1, 2002 | 07:30 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Looks really good.
How I wish I still had my car so I chould mod it...
Old Oct 1, 2002 | 07:43 PM
Engine: 5.7 / 7.4
thanks, for the tail lights, the darker ones are the new ones. alot darker than my stock ones, yet just as bright at night & w/ turn sigs and whatnot.
The intake, well, the things one must do because of the MAF hardest part will be making a good seal between the filter & inner panel, & filter& the elbow piece.
Old Oct 2, 2002 | 07:01 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Not bad, looks kinda like my idea. I used different material. However, with the space we have, I belive all of us route the CAI to either the right side, or under the car. So whos to complain??
Old Oct 2, 2002 | 05:08 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
hello i have an 85 2.8 too, and i have two questions , How did you do this..what material? and how much does it increase performance?
Old Oct 2, 2002 | 06:29 PM
Engine: 5.7 / 7.4
I'll give ya p/n and $ figures in a couple hours
Old Oct 2, 2002 | 09:45 PM
Old Oct 2, 2002 | 11:28 PM
Akshay's Avatar
Hey Project: 85 2.8 bird.
How wide are your rims on your Grand Prix GT?
I was told they were 16x5.5. That can't be right!
How does it drive?
Akshay
89 RS T-5
Old Oct 3, 2002 | 04:54 PM
Engine: 5.7 / 7.4
Intake:
3"X5' pvc pipe 5.43
3" 45* pvc street elbow 2.20
4"-3" flex dwnspout adapt 9.33 for 3, or 3.11 each
3" vent elbow 4.89
have only used 1 of the flex adapters, will return those & the 45* elbow & get another 45* elbow w/the two big ends. new idea brewin.
Grand Prix GT: I belive I have 225-60R16 on all four corners. wheels should be slightly bigger than 16X5.5
and yes, it handles & drives schweeeeeeeeet!!!!! :hail:
Old Oct 3, 2002 | 11:31 PM
Engine: 5.7 / 7.4
I'm committed now......
did the cut out for the intake:
Holy rusted metal, Batman
also did a mod on the flex tubing.......put a 9-10" peice of pvc tube in it just after the 45* piece, now it looks gay, but is smooth inside up to about 2" before the tb. should give it that extra umph!!
Old Oct 4, 2002 | 10:39 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sweet! I like the air filter placement, that's almost how mine is. 'Cept, I routed my flex air hose thru the inside of the fender, and below that battery tray. Did you see how your setup allows for a ram air? I tried to put it into words here: https://www.thirdgen.org/techbb2/sho...hreadid=118843
Old Oct 5, 2002 | 08:33 PM
Engine: 5.7 / 7.4
finally broke down & read the post. I think mine is better than everyone elses for 1 reason: Free K&N filter . As far as the cable to raise the air dam cover, maybe use one of those manual carburator choke cables. I'm thinking of removing that plastic thing on the bottom of the bumper support & put a scoop* of some sort to direct air. maybe like Karls.
* making sure not to take too much air flow from radiator
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
