Fuel smell....
Old Oct 7, 2002 | 10:29 AM
92bird's Avatar
Fuel smell....
Hey, I get out of my car sometime and I smell gasoline... Is this normal or should I check something? My cap is on tighly, 3 clicks, but the odor is really strong when I get out of it after going somewhere. Is it fumes from exhaust or gas not burning.....or should I change my fuel filter. I don't know just wondering.
Old Oct 7, 2002 | 11:16 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did you know about the filler neck safety recall? Look it up at http://www.alldata.com and call your dealer. Pinholes could develop at the seam between the fill neck and tank, and cause a fuel smell or fuel leak on the 91-92 f-bodies. (Not sure if this extended to 90, I think it started in '91.)
Old Oct 7, 2002 | 12:43 PM
92bird's Avatar
nope didn't know about that....great.
Thanks for the info Tom. Let you know what I find out.
:hail:
Old Oct 7, 2002 | 12:55 PM
92bird's Avatar
Well, I did find the recall notice, but I don't know if it was fixed since I have had the car, only 2nd owner and since I smell the gas........probs not. Will I have to pay for it or will pontiac pay.....Kinda curious how that works, and how long that they accept responsibilty.
Old Oct 7, 2002 | 04:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
They'll run your VIN and find out if it was brought in or not... if not, they'll bring it in, and perform the inspection, and possibly tank replacement, for free. That's what's special about a "safety recall" as opposed to other recalls.
Just like the seat belt recall, which I hope all of us know about, and have had the work done for.
Old Oct 7, 2002 | 11:32 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
'90 isn't covered.....which is TOTAL BS.
Old Oct 8, 2002 | 07:40 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
could also be a hole in your gas tank. they like to rust out at the top from people not filling the tank all the way up.
Old Oct 8, 2002 | 09:53 AM
my91rs's Avatar
Car: 91 RS
Engine: 3.4L
Ok Tom......I called on my tank and they said I was nuts. They dont have any record of a recall on our cars.
Old Oct 27, 2002 | 12:04 PM
burnham59's Avatar
I have an 86 and I get the same smell after a hard run. I see what looks like a pressure bleed of valve attached to the tank. I suspect thats where the smell comes from. I dont see any leaks and rust isn't a problem in Az. The smell isn't all the time only after a long run. I just figure it is normal.
Old Oct 27, 2002 | 12:39 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I had that, as well as my car not running quite right. Turned out to be a broken spark plug wire, in the boot. New wires, and she runs fine - no more gas smell! Could also be a leaky injector?
Old Oct 27, 2002 | 09:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, they're idiots then. Did you do what I said, to go look up the data yourself at http://www.alldata.com ? You can even get the recall from the government's website, which I think is http://www.nhtsa.com (nat'l highway traffic safety administration). Get the recall # then go call another dealer... because sounds like even if you do point that dealer that you called in the right direction, they'll either refuse to do the work, or do a shtty job.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
