vacuum connector behind the intake manifold (please look)
Old Oct 9, 2002 | 09:16 PM
squirrelybird's Avatar
ok ok...i broke this little plastic fitting off when changing my cap.....it connects 3 vacuum lines right above the distributor/behind the intake. its kinda like a T connector...two of the lines are one size (sorry dont remember the sizes) and one is a little bigger. now heres the thing....it is KINDA LIKE a "T" connector, but it has like this little cone/cylinder shaped body......well i ran down to the local store and they didnt have anything like that so i put a regular "T" connector (with the correct size parts).........heres the actual question does that little cone part do anything????? do i need a new one, or will the plain connector do the job????
Old Oct 9, 2002 | 09:24 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
It's a vacuum check valve. You need to replace it with the same part. It limits air flow to only certain directions.
Go to a dealer and ask for a vacuum check valve with 3 fittings; (they also make those with just 2 fittings)they should have it. The parts department at my work stocks them so I assume most places have them.
Old Oct 10, 2002 | 06:46 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Auto Zone, orlieys, advanced also sells them. Take a 2.5yo into the store, she will find it when you can't Been their, done that!!!!
:hail: :hail: :hail: To little kids
Old Oct 10, 2002 | 08:59 AM
thanks guys...will have to get around to that.
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Jake_92RS
Aug 11, 2015 10:39 AM
