This is the pump in question:
All RED arrowsx are places that (I think) have holes, as half these bolts are gone from the previous owner, I'm not sure.
All RED CIRCLES are the pump/to bracket mounting holes.
All BLUE CIRCLES are the REAR bracket mounting holes.
I have removed all RED ARROW bolts, and BLUE CIRCLE BOLTS, and still it stays tight on. This thing should have no reason to still be on!!!
The pump has a slight wigggle, like there is one or poss. 2 bolts left in it, but where beats the h3ll out of me.
HALP! LoL
HALP! LoL
Do you mean the pully it self wiggles? if so mine does that to you can see a slight wobble to it hasent caused me any problems. It did this after i replaced.
On the A/C bracket, pull out the long bolt that is FARTHEST to the RIGHT in that pic. Just above the 2 red arrows.
Then , you will have to kinda wedge the pump out.
did you pull the bolt out that's behind the pump? it bolts directly to the block if i remember correctly. i just put a new engine in my car so i had to remove this bolt to get pump off.
If I remember correctly don't you have to take off the ac and set it aside in order to get all of the ps pump bolts off?
no, you don't have to take the ac off.
I removed my PS pump to install a new water pump.
From your arrows and circles I think you missed one bold.
I back, botto I believe, you'll have to look in with a flashlight, under the AC pump there should be a bolt fixing the bracket there.
(I did not have A\C, so it was quite easy to remove. But from that picture I do not see this bolt labled)
