engine problems?????
Old Oct 20, 2002 | 05:04 PM
f41camaro84's Avatar
i put another 2.8 into a frind of mines 87 firebird, (the engine that was in it had a rod knock). after i put a new engine in it, started it and it idled fine. but it has no power, i can't get the car over 20 mph, and won't make it up a hill. i know the cat isn't a problem because 1st it worked before and 2nd it has a exhaust leak between the manifold and y pipe. the TPS is good, MAF is good, it has all new plugs and wires, cap and rotor, new plenum and runner gaskets. i can't seem to figure out what's wrong with it. i checked all vacuum lines, and their locations. that's all fine. is there anything i'm forgetting to check? please help!!!!!!!!!!!!!
Old Oct 20, 2002 | 06:48 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you did remember to reintall the 3 torque convertor bolts right j/k
did you mess any w/the tv cable?
Old Oct 21, 2002 | 10:05 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Timing set properly?
Old Oct 21, 2002 | 02:45 PM
LT1guy's Avatar
Car: 1987 Trans Am
Check the trans fluid.
Old Oct 21, 2002 | 07:07 PM
no, i checked the timing and it's perfect.... trans fluid reads full hot, after the car's been running a while. i can't seem to solve this problem..... is there anything i'm forgetting???????????????
Old Oct 22, 2002 | 07:10 AM
LT1guy's Avatar
Car: 1987 Trans Am
Fuel pressure maybe?
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
