What Mods Do You Have?
Old Oct 27, 2002 | 12:28 PM
ThroopBird's Avatar
What all mods do you guys and gals have?? From intake to exaust to plugs to tires.. any thing i would like to see some pics if you have them..and most i was wondering about was intake and exaust..tell the kinds the make the price if you know ...thinks for help cant wait to here from eveybody!
adam throop
Old Oct 27, 2002 | 12:30 PM
V6camaroman's Avatar
all my mods are in my signature.
Old Oct 27, 2002 | 12:35 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
see the sig
Old Oct 27, 2002 | 12:36 PM
Doward's Avatar
? Where's my sig?
Old Oct 27, 2002 | 12:37 PM
Doward's Avatar
sig test...
Old Oct 27, 2002 | 06:59 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
In the sig.
Old Oct 27, 2002 | 07:02 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Do you have any times?
Old Oct 27, 2002 | 08:01 PM
nope no times yet. im gonna go to the track this comming spring. tommarow im gonna be putting in the accel coil and 160* thermo i just got in it. i have some plans this winter also including an asp crank pulley and 3:73 gears & a posi unit. im hopping for mid to high 15's now and maybe low 15"s with the gears.
Old Oct 27, 2002 | 11:12 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
What's your 0-60?
Old Oct 27, 2002 | 11:37 PM
KED85's Avatar
I install 3.4 mills under the original 2.8 induction/igntion systems.
Works fine, smog legal.
Accel products for ignition & I like Bosch plugs.
You live in New York State & ya wanna install a 160* thermo....
Suggestion, stock 195 or atleast find a 185*.
You seriously could make some computer trouble by using a thermo so low in temp (MAY cause the ride to run very rich all the time and waste gas, plugs, etc...... again, MAY do that).
I AM ALWAYS AWAITING smog legal headers!
Old Oct 28, 2002 | 08:21 AM
90RS3.1's Avatar
im runnin 16.5 with exhaust intake Accel ignition ect.
I took an apc air intake built for a honda civic an bolted it right up. It fits perfectly and puts the filter right behind the headlight bucket where the stock filter canister would go. Ill post a picture later when im not on a school computer. But it actually does work quite well. I pop the headlight out n the intake is right there..almost a mini ghetto rigged ram air.
Old Oct 28, 2002 | 09:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Everything below has been installed by myself...
intake, custom cold air w/large K&N conical
exhaust, factory manifolds, hogged out the manifold-to-y-pipe "donuts", AP mandrel-bent y-pipe, PFP high-flow catalytic convertor, Dynomax super turbo cat-back, Megs chrome rolled edge tips.
ignition, rebuilt distributor (stock parts), Accel distributor cap/rotor kit, MSD 6AL, MSD Blaster SS, MSD 8.5mm universal (cut/crimp my own) wires, AC/Delco plugs (ran Splitfires for 5 years, but when I put the MSD on, the MSD chewed the splitfires up) gapped to 0.050", stock timing (10 degrees), original GM computer chip
700r4 automatic trans, B&M shift kit (not good for trans, the TransGo kit is what you (and I) want), B&M 4-3 kickdown kit, B&M Megashifter, B&M Super Cooler, Summit remote trans filter kit, Energy Suspension trans mount, Energy Suspension torque arm mount
engine, original 2.8 with 241,000 miles, cloyes true dual roller timing chain
free/cheap mods, removed a/c system, tb bypass, 160 thermo in summer and 195 thermo in winter
rear axle, WAS my 3.73/posi/disc from an '84 transam, rebuilt with new axleshaft bearings/seals, POR-15 paint, rebuilt rear calipers, changed car's brake system (m/c, prop valve, front-to-rear brake line) for 4-wheel-disc. NOW, the axle's locker blew out, back on a junkyard axle, $100, from '88 camaro 2.8, same as my old stock axle (3.42/open/drum).
suspension, monroe sensatrac struts, gabriel high-jacker air shocks, Energy Suspension anti-sway-bar end-links and mounting bushings, American Racing ar-46 rims, tires are BFG Radial T/A, front P225/60r15, rear P275/60r15
Ran a 16.87 in '97 with "only" a cat-back exhaust, rest of engine was in poor running condition (clogged filters, mixmatched set of plug wires, trans died a month later, etc). Mileage was probably about 120,000. Last run, a few years ago, with all the above mods on, was a 17.1 with a TCC lockup switch, at about 200,000 miles.
Old Oct 28, 2002 | 12:22 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
TOM P you have 241,000 miles is it still the origonal engine or rebuilt im at 215,000 right now.
Old Oct 28, 2002 | 01:49 PM
KED85's Avatar
And Fast RS's engine is STILL A STRONG RUNNER, TOO!
An opinion from his passenger
Old Oct 28, 2002 | 02:35 PM
Quick6's Avatar
Please post a pic...and where did u get it? How much? Thanks
Old Oct 28, 2002 | 03:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
"original" as in, not rebuilt! It gets up and goes alright, but the track times just aren't reflecting it. I'm betting my camshaft lobes are worn down all to hell.
Although I can't wait to rebuild an '87 2.8 and drop it in... hopefully this summer... but I said that for Summer of '02 (sigh)
Old Oct 28, 2002 | 04:31 PM
90RS3.1's Avatar
Quick 6
I got it at pepboys when i worked there for 60 bucks with my discount. i think its 80 normally. here is a link to a site where i have pictures.
http://www.angelfire.com/rpg/dangrou...loyd.pics.html
Old Oct 28, 2002 | 06:08 PM
Originally posted by mike1986fyrbird
What's your 0-60?
i dont have acurate times but im guessing 7-8 sec. my 60 ft time is prolly 2.2 sec.
Old Oct 28, 2002 | 06:54 PM
Camar_Hunter_c's Avatar
In about 5 days, 6 people will have headers listed LOL!.
Old Oct 29, 2002 | 02:34 PM
Quick6's Avatar
Quick 6
Would an intake kit from say Greddy or AEM for a civic bolt right up to? Thanks.
Old Oct 29, 2002 | 02:57 PM
90RS3.1's Avatar
It depends on which type it is. mine is kind of a short ram set up. if you get the type that goes down into the fender then no it wontwork. if you get the type like i have then it will fit. APC makes the one i have and it works perfectly. Plus i didnt have to worry about a mass air flow because i have a speed density sensor.
Old Oct 29, 2002 | 03:08 PM
Quick6's Avatar
Do you have the part number for the apc one you have? Also, what do you mean about the speed density part? Is that something I need to worry about?
Old Oct 29, 2002 | 04:48 PM
90RS3.1's Avatar
not sure on the part number i just know its for a civic and pepboys sells them.
On my car i have a speed density sensor and not a mass air flow sensor...im not sure if the intake will work if you have a mass ari flow sensor.
Old Oct 29, 2002 | 04:49 PM
Quick6's Avatar
How do I know which I have?
Old Oct 29, 2002 | 11:07 PM
KED85's Avatar
What year car ya got?
It's 90-92 3.1's that are minus the MAF
Old Oct 30, 2002 | 06:56 AM
ThroopBird's Avatar
Hey man i got air flow sensor on my intake...stock..i just disconnected mine yeaster day and it did not diff..i think if you have it on there it make kill the engine if to much flow but if you take it off ...it will not kill engine..dont worry about it..just get intake and disconnect air flow system..im getting an intake from pep boys really soon!!....is that honda one better than a pcp pipe one you make your self..and how much hp do you think it gave you??
Old Oct 30, 2002 | 09:27 AM
KED85's Avatar
They tend not to give very much HP unless ya drive fast.
WHY
No air getting to it.
Must have air forced into it to be truly effective.
A PVC set up is dirt cheap to experiment for best placement.
Ya feel the difference MOSTLY when passing cars at freeways speeds, but around town, will just make more "noise".
gain is usually about 5HP or so
Again best results for the air flow increase is in passing on freeways and a higher top end speed.
Old Oct 30, 2002 | 09:36 AM
90RS3.1's Avatar
Thats true ked.....nut im trying to change that. im going to try and modify the healight bucet somehow to give it a forced air set up. ill let yas no how it turns out
Old Oct 30, 2002 | 02:38 PM
Quick6's Avatar
1991
Old Oct 30, 2002 | 03:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Throop, you should really re-connect that MAF sensor. Running without it puts the computer into limp-home mode, and you're not running as strong as you could be. The sensors are there for a reason, dude! Besides, the stock MAF can handle more airflow than the 2.8 engine will ever use...
Old Oct 30, 2002 | 04:08 PM
Keoki_Firebird89's Avatar
Check my sig for mods.
the intake is like RS
i have a honda intake and bolt it right, its hovering above the battery. So i have a big open nothing where the original set up was.
I'm hoping 16s
and i definitely don't know my 0-60
Old Nov 1, 2002 | 09:05 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
See Sig
Old Nov 2, 2002 | 06:43 AM
wait heres my sig
ok
i have NGK plugs in case i don't have them
not platinum cuz i plan going turbo
so platinum will kill the engine.
its bad for MSD too which i plan on getting as well
the intake i have is from a honda short ram intake.
i bought it off discount auto parts i think.
its blue and fits right in with the right brains
doesn't take much
just buy the cheap honda short rams you find in those kind of stores and buy them (Pep Boys, Discount Auto Parts, Auto Zone) thinks like that.
tke care...
hope sig is up this time..... sigh
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
