painting plenum
Old Dec 1, 2002 | 06:55 PM
92RSMuscle's Avatar
painting plenum
how do we paint our plenum?
i dont wanna polish it...but maybe paint it chrome or some crap
Old Dec 1, 2002 | 08:50 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you mean like this:
just clean up real good, & give it couple coats.
Old Dec 1, 2002 | 09:10 PM
92RSMuscle's Avatar
how did you get it so shiney? did you prime it and sand it?
i have a red camaro, what color would look good?
Old Dec 1, 2002 | 09:21 PM
Engine: 5.7 / 7.4
used either the 1200* or the 500* spray paint, I forget. the finish was dull, so it hit it w/some clear cote & it just shinyed right up!!. give it a lot of cotes, as spray paint doesn't go on that thick.
edit: clear cote was same temp range as paint
Old Dec 1, 2002 | 09:44 PM
92RSMuscle's Avatar
you took the plenum off the car right?
what about gaskets?
Old Dec 1, 2002 | 10:11 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
what about gaskets?
I would hope so....
Old Dec 1, 2002 | 10:30 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have pic on link below in profile of mine. It was off the car when I painted it. I just used scotchbrite pad, and some prepsolve (degreser) and then misted on many of coats, then cleared on top of it.
Mine don't even have a heat range on it, and its sticking fine.
Old Dec 1, 2002 | 10:33 PM
Engine: 5.7 / 7.4
painted the plenum when I did the engine swap
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
