Idle problem and shakey volt meter
Old Dec 3, 2002 | 10:18 AM
aaronkark's Avatar
Hello I have a problem with my crappy V6. The car idles like crap when cold and the volt meter stays above the middle but shakes around alot. The computer says the egr is bad but does anyone know if this actually causes the symptoms I mentioned above. Also when it is cold and runs bad it just about stalls and then it revs up and then back down again on its own. 88 2.8 camaro
Thanks for everyones help,
Aaron
Old Dec 3, 2002 | 10:53 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Yes a bad egr valve could cause that BUT
What condition are your vacuum lines in? If they're bad, an EGR code could be done as well.
What shape is the plugs, wires etc. maybe time for a tuneup?
Did you clean and reset the IAC?
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
