Need help fast !!!!!!!!!!!
Old Dec 3, 2002 | 06:15 PM
alexuk's Avatar
Hi
1988 V6 Chevy Camaro RS
well here goes just did my clutch no problems there
but after 2 days going to work coming home it started to run rely rough like
it was not firing on all 6 cylinders ,
I have change spark plugs and the wires ,distributor cap and rotor before I
change the clutch
when it cools down it seems ok again and it will even start ok when hot and
will tick over but sounds rough
any help would be helpful as I have work tomorrow and will have to use the
camaro to get there and hope I do not screw it up any more
Hopefully
Alex
p.s if you need more info please feel free to e-mail me
Old Dec 3, 2002 | 06:47 PM
HurtHorseZ28's Avatar
Check plug gap, Check your timing. That's the first thing I'd check.
Old Dec 3, 2002 | 07:31 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
SES light coming on?
When the MAF goes the car runs perfect cold, but once it reaches driving temperatures (10 minutes later) the car will hesitate, stall when you stop for a stop sign. Simular to what you have described.
Old Dec 3, 2002 | 07:49 PM
alexuk's Avatar
Hi
thanks for the help
well I think I have found out what it is when I got the spark plug wires I was given the wrong ones I was given the ones with the elbow at the end and not the ones with the long tube on as they were cheap I thought that was why
any way one of the wires had melted on the exhaust and was shorting out if it had not been dark I would not have seen it
yes I know am a dumb *** :-)
any way i have taped it up and put it out of the way and it seems to run ok now
it will have to do untill i can aford to get the rigth ones
onces again thanks for the help
Alex
Old Dec 4, 2002 | 08:21 AM
You say you were GIVEN the wrong wires? If an idiot guy behind the parts counter gave me the wrong part, I put it on and had problems, I'd take them back and exchange them for the correct part, burned wire or not.
Old Dec 4, 2002 | 09:09 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Aggred, unless you bought a set that was "custom" make, then you are sol.
Old Dec 4, 2002 | 01:10 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Mine are SUPPOSED to be "Custom" from Taylor..but guess what? Passenger side is way too long...by at least several inches per wire. Seriously though yeah, take the wires back. These auto places..they may bitch, and moan, and try not to give you exchanges and stuff claiming it's your fault..but guess what? Business rule still applies..the customer is always right. You get pissy enough with them and they'll give you whatever you want. Trust me..it works... I've done it once or twice.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
