S-10 V6 vs. Camaro V6
Old Dec 26, 2002 | 12:10 PM
bigpuncp27's Avatar
Car: 1987 camaro
Engine: 2.8 MPFI
Transmission: th7004r4
Can anyone tell me if there is any difference between the truck 2.8L and the Camaro 2.8L?
Old Dec 26, 2002 | 12:16 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
1 comes in a truck, 1 comes in a car.
Old Dec 26, 2002 | 12:59 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Camaro is MPFI, truck is TBI.
Block, timing chain, heads, crank, pistons, all the same.
Diff is mainly in oil pan, intake design, valve covers.
Old Dec 26, 2002 | 01:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dale, is the cam different, too?
Old Dec 26, 2002 | 02:30 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
i'm pretty sure it is
Old Dec 26, 2002 | 02:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
unless its a question about a specfic year it not an answerable question, but a 2.8 is a 2.8 , it just might have different fuel delivery and a different cams but its all the same.
might as well say the 3.1 is also, all parts are swapable, but pistons.
Old Dec 26, 2002 | 02:48 PM
Dale's Avatar
Engine: 350 S-TPI
I am not sure on the cams to be honest. Thats why I didn't type anything about them.
Old Dec 27, 2002 | 10:53 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
the bore on the 2.8 and 3.1 is the same. the stroke is different. i'm building a new 3.1 off of a 2.8 block, put a 3.1 crank in it (bored but that was just because i already had the bigger pistons, stock bore is the same though).
Old Dec 28, 2002 | 08:58 AM
KED85's Avatar
IF you get specific with the truck/car engine years, the answer can be more specific.
Blocks - same
Heads - DIFFERENT/SAME (depends on vehicle-diff is valve size. Rest of head is same (no better "flow" except by larger vlave)
Cams - See above, replace valve size w/cam specs.
Cam Carb'd version of truck/car is same - wimpy
TBI Truck cam - probably same as the carb
MPFI car cam is most "aggressive"
manifolds - intake - it's obvious
manifolds - exhaust - different is vehicle is Carb'd truck or car. Besides that point, they bolt on identical.
On a rebuild/worth grabbing ratio, search for a 3.4 mill.
Start with the best parts for more smiles per miles.
I can give an exact answer that...
2.99" stroke is a 2.8 crank.
3.31" stroke is a 3.1 crank.
3.31" stroke is a 3.4 crank.
GM Publication.
DETAIL
DETAIL
DETAIL
You NEED a 3.4 block to make a 3.4 mill.
There isn't enough meat in a 3.1 block to make a 3.4.
You'll be more prone to constant engine overheating & eventually crack block-hit water.
BORE
3.582 = Max for 3.1 block (am I correct as ya building one-my answer from a GM publciation)
3.62 = THE (starting point) STANDARD SIZE BORE FOR A 3.4
mat89RS
Jan 7, 2003 08:10 PM
Rockin88305
Jan 7, 2003 02:16 PM
Joey1986Z
Nov 24, 2002 10:59 AM
Matt383
Jun 20, 2002 09:08 PM
lankchevy_350
Theoretical and Street Racing
19
Apr 8, 2002 07:09 AM
