Putting 3.1 on engine stand
Old Jan 6, 2003 | 06:21 PM
AmorgetRS's Avatar
I am having issues putting my new 3.1 on an engine stand to work on it. The far left, while looking at the tranny side of the motor, the bolt hole has a dowel type thing in it and I cannot get it out. Is there a trick to getting it out? Would it be safe to use only 3 of the mounts? Any help? I can take pics if needed....
Old Jan 6, 2003 | 06:46 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I'm gonna e-mail a pic of the 2.8 in the stand. I used all 4 arms, in a jacked -up looking config. I ha to use 7/16" I think, bolts, as neither AZ nor nappy had the exact metric ones.
edit: leave the dowels in. Their pressed in anyway & you really don't want to lose them if you somehow pry one loose
Old Jan 6, 2003 | 06:55 PM
AmorgetRS's Avatar
LOL, okay, I sent you an e-mail, ignore. Anyway, the issue is that it won't sit flush, it'll be uneven which will put uneven pressure on the engine stand.
Old Jan 6, 2003 | 07:04 PM
Engine: 5.7 / 7.4
I had the 3.4 w/everrything on it, & the 2.8 has been on the stand now for about 4-5 mos. I'm using the $40 stand from AZ.
Old Jan 6, 2003 | 07:06 PM
AmorgetRS's Avatar
So basically just let it be uneven and tighten everything nice and tight?
Old Jan 6, 2003 | 10:00 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
there are six holes in the block and only four arms on the stand. there are only two pegs, just stick the arms in the other two holes. those stands were made to take the abuse of even a beastly bbc, they will hold the measly 60* with the arms **** eyed very well, trust me, i did it for 2 months straight.
midge54
Dec 27, 2019 04:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
the_nikfive
Aug 11, 2015 02:46 AM
