2.8 to 3.1
Old Jan 23, 2003 | 05:51 PM
92Z28CamaroRulz's Avatar
2.8 to 3.1
K guys, You can scrap that 4.3 idea, Ok, I found a 3.1 V6 with a 4 speed overdrive auto tranny for 300 dollars with a 1 year warrenty, What things would have to be swapped for this to work or will it just pop right in?
Old Jan 23, 2003 | 07:25 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
2.8 and 3.1 are essentially the same motor..the 3.1 is just a 2.8 with a stroke kit. However, the computers are different in several ways. One of which is, 2.8's were MAF cars. 3.1's used a Speed Density system utilizing an MAP sensor. So you'll have to make sure the new motor has the Map sensor and vacuum line for it, and a functional computer for it.
Old Jan 23, 2003 | 10:30 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
as Karl would say: "Make the 3.1 lok exactly like the 2.8 you replaced it with,....minus the 2.8 MPFI circle" :nono:
Old Jan 24, 2003 | 09:36 PM
godsapprentice's Avatar
I swapped in a 3.4 in place of the 2.8. Nothing major had to be done. I swapped the 3.4 injectors into the 2.8 fuel rail and swapped all the externals from the 2.8 over. ie, intake, brackets, mounts, sensors. By using the original intake and sensors, the original computer can be used as well. The engine runs great. The only thing I can give you a heads up on is that I didn't replace the water pump or timing chain for financial reasons. This means I didn't change the harmonic balancer. The 3.4 balancer does not have a timing mark, so I had to time it strictly by ear and performance. Other than that, it is really a simple swaps as far as motors go.
Old Jan 24, 2003 | 09:55 PM
Engine: 5.7 / 7.4
what yr 3.4? mine (balancer) has a timing mark on it, just like all the Poncho 400 have them. I just transferred the timing teeth off the 2.8 & used one of the water pump bolts to hold it on. When I go to time it, I will use my multimeter & ears.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
