how to check for a vaccumm leak
Old Jan 24, 2003 | 05:50 PM
alexuk's Avatar
how to check for a vaccumm leak ?????
Hi
well the subject just about says it how do i check for a vaccumm leak
i have a 88 camaro 2.8 V6 which is reving high(2000 RPM) and i have to keep jabbing on the throttle to get it to come down (about 750RPM ) i have change the IAC and no change and some one told me i may have a vaccumm leak but i do not know how apart from looking at them but as hard as i look i can not see the air leaking out or in :-)
Alex
Old Jan 24, 2003 | 07:31 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
get some carb cleaner(spray can). run the engine and spray shots of it around areas that you think have a leak. you will notice a difference in rpm while spraying carb clean when you find the leak
Old Jan 26, 2003 | 08:27 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
did you check the timing. I retarded mine(just until i'm done with smog) and it came back down to about ~650, but i still have the throttle stick problem that you have. By the way, what color is you car. we basically have the same car and it's interesting how they are having the same problem at the same time.
Old Jan 26, 2003 | 08:56 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
They sell a vacume guage at about any parts store, is cheap too. thats best accurate way to check. Needle bounces, you have issues. Needle steady, it is fine.
Old Jan 26, 2003 | 08:59 PM
alexuk's Avatar
Hi
well good news sorted mind out
and it was me being a dumb *** i put the air lines in the wrong way on the TB
I have a Black 88
i still have allot to sort out 1 is the paint work
just win some new rims on E-bay when i got the car it had taty 14" when it should have 15"
any way if i can help let me know
Alex
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
