Is this just "Snake Oil"??
Has anybody heard of the Venom 400 before?
Seems too good to be true, it's available for a bunch of our V6's.
http://www.coximport.com/venom/400.html
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
88-89 2.8
The fuel injectors might be good if they are not 55.95 each
http://www.coximport.com/store/HP645-405
Venom High Flow Fuel Injector: HP645-405
Quantity in Basket: none
Code: HP645-405
Price: $55.95
Shipping Weight: 2.00 pounds
http://www.coximport.com/store/V45-128
Venom 400 Control Module: V45-128
Code: V45-128
Price: $300.00
Shipping Weight: 5.00 pounds
88-89 Camaro/Firebird 173/2.8L VIN S
All VENOM 400™ Performance Control Modules include FREE OVERNIGHT SHIPPING!!
Select free ground shipping at the checkout and and your VENOM 400™ Performance Control Module will automatically be upgraded to overnight.
The VENOM 400™ Performance Control Module is an add-on control unit that features its own micro- controller. This module is connected to the vehicle's sensors and increase engine performance by monitoring the sensors output characteristics and modifying the input to the existing vehicles computer.
http://www.coximport.com/store/HP745-200
Venom High Flow Fuel Pump: HP745- 200
Code: HP745-200
Price: $179.95
Shipping Weight: 3.00 pounds
88-00 GMintank
Code: HP645-405
Price: $55.95
Code: V45-128
Price: $300.00
Code: HP745-200
Price: $179.95
88-00 GMintank
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Doubt it would help any more than an aftermarket chip would.. There are much better ways to spend your money.. Although I do admit, it DOES sound pretty attractive after that ad... But 25% power gain from it MODIFYING what the sensor outputs are so it tricks the computer?? Sounds a little strange to me..... As well as the eliminating the downshift flat spot on autos....?
They say 'up to 25%' gain, but they don't tell you how well the engine ran to begin with that they got the numbers from. It could have already been a bit out of tune. It probably would gain you a little bit, mostly by adjusting the fuel and spark curves, but that would probably be more in the 8-10% range, not 25%. They probably also say that you must use 93 octane gas. For people like me who are using nitrous, one of those would grenade the engine, since it would try to advance the timing and then detonation and piston distruction would occur. I think that there are other ways that you could spend money more effectively, performance wise.
As far as reducing downshift delay, I don't think it would affect it at all on our cars since I'm almost positive 82-92 autos were all mechanical and the electronic auto wasn't in f-bodys until 93 or 94.
David
David
Right.... So yeah, this sucker probably has the same type of effect as a replacement chip would...although it's supposed to be able to enhance a chip further.. I just don't see how a little box that modifies the sensor outputs could work WITH a chip. Ok, let's say the programming in the computer isn't the most efficient at making power, which it isn't...ok so by modifying the sensor output, the box tricks the computer into recalculating things and adjusting the car to work the way it SHOULD for power, right..? Makes sense.. BUT, a chip changes that......it's DESIGNED to add performance. So, how would a box that MODIFIES sensor outputs possibly HELP a chip rather than hurt it?
12 Sec GTA
Theoretical and Street Racing
32
May 31, 2003 09:02 AM
383backinblack
27
Nov 24, 2002 10:37 PM
