V-6 Engine HELP!!
Old Sep 28, 2003 | 11:22 AM
  #101
KED85's Avatar
UNDER BLACK valve cover on ORANGE cylinder head behind the metal tube is the location of the fan sensor switch. It's that dark circle you unotice.
EVERY SINGLE RWD 60* cylinder has this hole.
This is a 1995 F Body 3.4 cylinder, too.
For our 3rd Gen F Body this is the location of the fan sensor switch.
IF no sensor there, you have a problem.
IF no single wire with spade female terminal for this sensor you have a problem.
IF that hole covered with a plug, you have a BIG problem.
The engine needs to be outta car for a plug removal, as it's next to impossible to access for any leverage.
Hope this leads you to the solution.
Serious, this is all the truth, ask at GM parts counter for print out & parts list for confirmation.
Attached Thumbnails V-6 Engine HELP!!-blzng-20bolts-20c-20dist
Old Oct 13, 2003 | 11:20 AM
  #102
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Axle/Gears: Stock round ones
green wire
my manual says it is for fan overide switch mounts on the head (right above number 2(drivers side)) behind my compressor
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
