Ignition Wires
Old Feb 27, 2003 | 11:10 AM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
Ignition Wires
I'm looking to buy a wire set...will the ones made for an 82-86 v-8 fit my car...cause i can't find any for a 2.8 and i know that most of the v-6ers here order a v-8 set with two spare wires...just wondering which ones to get...msd or accell...i'd like to go with accel and make a complete accell ignition setup...but if i'll mix things up if i'll get a better result...thanx for you help
Old Feb 27, 2003 | 12:08 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Myself and someone else on the board dislikes accel wires. However, ked85 praises them.
I am running taylors on my s10, and plan on putting them on camaro and dodge sometime.
All ideas, and no money
Old Feb 27, 2003 | 12:49 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I'm running Taylors too...they make a custom set for us, but they apparently aren't THAT custom because several of the wires are cut WAYYYY long...but other than that, I have no complaints for them. They're real pretty wires and didn't give me any problems before I sold the car. I got the set for about $55-$60 ordered at the local speed shop. The V8 wires...I'm not sure about the length on them, but you can always trim them if it comes down to that..but I prefer to buy the ones that come crimped and booted from the factory.
Old Mar 1, 2003 | 10:04 PM
V6camaroman's Avatar
ive got accel spiral core 8mm wires. they are a universal sbc set and i had them custom cut to the v6 specs. i dont remember what they cost i would have to look the slip up i got them at advance auto though. i also have the accel coil cap and rotor
Old Mar 2, 2003 | 11:32 AM
devianb's Avatar
Right now I have 8mm Crane Cams wires. Over spring break, I will crimp and cut my MSD wires that I picked off of 71 351W. I am not using them now becuase they have the socket style distributer boots. I got them to work with my HEI, but they were still kind of loose. I have the new HEI boots, but I haven't gotten around to crimping them.
If you get a set from a V8, make sure the spark plug boots are straight.
Old Mar 2, 2003 | 05:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I recommend getting the v8 set, and only using 6 wires- if you're buying a "universal" cut/crimp/make your own kinda-set. If you buy a precut set, the wires will probably be way too long- but I think you knew that already.
Yeah, I use the MSD 8.5mm SuperConductor wires, and always bought the V6 kit- until I noticed the v8 kit with 2 extra wires was only $8 more. Best part; if I get up to 3 v8 kits, I'll have a "free" v6 kit!
I know what you mean about staying with all one brand... I had an Accel remote HEI "computerized supercoil" on my car.. when the girlfriend bought me the MSD 6AL kit, I put the Accel coil in the basement, and bought an MSD Blaster SS coil- just to keep everything matched.
Old Mar 2, 2003 | 05:36 PM
devianb's Avatar
All of my ignition parts are Accel, except for the wires. I have heard to many bad things about them to not use them. The most common complaint was that the wires would fry or melt.
Old Mar 2, 2003 | 07:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Weird... I bought my dad a set of Accel Super Sport (8mm) wires for his truck; they're still okay. Then again, he doesn't have any aftermarket ignition setup; still using the factory coil, too.
Old Mar 2, 2003 | 08:00 PM
devianb's Avatar
The V8 Accel wires in particular would tend to melt due to the excessive heat from aftermarket performance headers.
Old Mar 2, 2003 | 09:02 PM
i have always used accel products on my car and have never had a problem with them. i hear msd products are good too ive never used them though. maybe on the next tune up ill go msd.
Old Mar 3, 2003 | 03:01 PM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
well...i have found all my parts needed...i will be placing the order in a few minutes...going with accel and also a holley ignition module...i went to a local speed shop...the only thing i will buy from them are my wires...summit is backordered on wires...and for a couple bucks more i'll get them right away and not have to wait until april...but i will always have a back up set of wires becasue the current ones on my car are lifetime warranty...when i put my new ones on...i'll take the old ones to autozone and get a new set in case of anything...umm...i got some other stuff going in over my spring break...new cat...i would write a new post...but its easier to post in here...i bought a universal cat and its 2 1/2" inlet/outlet...howver...i know the y-pipe from the manifolds is smaller...so i would have to put an adapter in there to make it work...anyone think i would have leaks using all clamps...i don't see a problem with it because the factory cat isn't welded...oh well...time to place my order...thanx again guyz...i'll let you know how everything works out
Old Mar 3, 2003 | 06:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The factory cat isn't welded, but will have a ball flange where it "exits" to meet the "entrance" to the intermediate pipe of the cat-back system. How much did you pay for the universal cat? You might've been able to get a high-flow cat for the same price. Your factory y-pipe should be 2.5" out... it isn't?
I've never had leaks using all clamps; nothing on my exhaust system is welded. That's just an old wives tale, probably told by people that forgot to check the tightness of the clamps after a few heating/cooling cycles.
Old Mar 3, 2003 | 09:06 PM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Hey Tom...I have already had the catback system changed as my profile states...actually...do they sell a flange kit for that or something...if not...i'll make it work...thats my motto...thanx again
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
