3.8
Old Mar 3, 2003 | 03:12 PM
firechicken_-54's Avatar
Car: 85 firebird
Engine: 2.8 HIPO
if a 3.8 is a 90 degree engine could i use the v8 bell housing to hook it up to the tranny, i think i might be picking 1 up off a buddy a mine, he has a 92 bonnvileand he's getting a new engine. so i want to know if its worth the 800$ for the swap and are the wiring harnesses hard to get
Old Mar 3, 2003 | 03:17 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
need more details on what it's for.
remember, the the 92 engine is a 3800 Series I. the blown versions of these are just as powerful as an N/A Series II.
a little food for thought
Old Mar 3, 2003 | 03:39 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Is a 92 bonnie FWD or RWD??
If its RWD, it should work.
Old Mar 3, 2003 | 03:51 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
FWD (and newer RWD for that matter) 3.8's use the same bolt pattern as the 60* V6
(yes, i was shocked when i found out too)
so if you can somehow get around having your starter on the wrong side (cut your tranny case maybe?, if you have a manual trans your prolly screwed because thats where the slave cylinder mounts)
IMHO its not worth all the work.......
Old Mar 3, 2003 | 10:34 PM
Engine: 5.7 / 7.4
if you go to the gm parts site, a replacement 3800 motor doesn't specify fwd or rwd. it fits both platforms
Old Mar 4, 2003 | 08:09 PM
Car: 85 firebird
Engine: 2.8 HIPO
thanks alot for the info guys i'll have to think about it all the work, and all the times my dad is gonna throw vice grips at me lol, and i'm really low on $$. the starter shouldn't be a problem i'll cut a hole in the floor if i have to. and i'm gonna check the gm sites.
thanks again guys
peter
Old Mar 9, 2003 | 12:48 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
if you're going to go through all the trouble why not drop in a real 3.8 that's already RWD?
Old Mar 9, 2003 | 01:02 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Ha ha...fly...if there is anybody out there that has actually gut a TTA, I will have them by the throat...those cars are too valuable.. Same with the Grand Nationals...
Old Mar 9, 2003 | 01:06 PM
fly89gta's Avatar
Car: 2018 Camaro SS
well my motor is a TTA motor, when they get totalled there is no use for fixing them, that's how I got mine...
AussiePr0nCar
Mar 6, 2020 04:04 PM
neilb
Oct 4, 2018 12:36 AM
99Hawk120
Dec 5, 2001 08:13 AM
Calderone
Jun 9, 2001 07:56 PM
