IAC i think it went out now :burnout:
Car: 80's somting Trans AM
Engine: 5.0L H.O.
Axle/Gears: not sure yet
My check engen light comes on and up gose the rpm's to 2,450 i think my IAC has went out. dose anny one know where this is located? if you have pictures please point it out thwere it is if possible thanks. :-)
Car: 85 Camaro SC
Engine: V6
Its on the throttle body, on the very bottom of this pic. It has the brass with plastic connector on it. Theres a tech article that might help you with the IAC, https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Engine: 5.0L H.O.
ok it dosent idel high all the time only every now and then and the check engen light comes on i was told it would be a sensor that dosent look like a sensor i dono thank though ill look at it
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Did you check the codes? Is it an actual IAC code? That picture IS of the IAC sensor, just doesn't look like a sensor... That's one of the older model ones..the newer ones, the clips come out of the bottom..it's much cleaner. If the old ones are like the newer ones, it's just 2 Torx screws to unhook it..then all ya gotta do is clean it with some carb cleaner and put it back in.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I have that style IAC on my car. Really easy to remove. Just unclip the connector, get a big a$$ wrench, I used as set of Slip-jaw pliers, and unsccrew it. comes right out. Clean it, and put it back. They hardly ever actually go bad, but do get "lazy" because the carbon gets around and into the motor. You can't clean the inside of the motor, so buy a new one is it's just lazy. It'll last you a while. Anyway, sounds like you may be having problems with a vacuum line also. So check those bad boys out while you're under there. Good Luck.
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
You should go buy a Hayne's manual.
And just so you know, Go's fast isn't spelled gose fast.
The IAC is NOT pointed to on the picture. That picture is showing you how to adjust your TV Decent Cable.
The IAC is IN that picutre. It is the only thing in the picture that is brass. It connects to the throttle body or something.
Car: 1986 Firebird
Engine: 2.8 V6
Cammy, 85SportCoupeto89RS DID tell you where it was in the picture.
Go buy a real shop manual from http://www.helminc.com for you car, it'll have more diagrams then you'll ever need.
Mike...I hate to call you on it man...but it's actually 'goes', not 'go's'..
Engine: 5.0L H.O.
that's ok about the go's not gose thing thanks for telling me like i said tell me if i misspell somting or somting like that, anny who about the picture. that picture of the TB dosent look anny thing like mine i dont have anny big brass nosel like that on the top or anny thing i have 2 plugs on the side and a hose that leads from the EGR to the intake maby it's because it's a 3.1 not a 2.8 or somting i dono well if anny outher pistures will help for that manual im saving up to get one. But i'm still paying for the car and insurance and calbe modem and gas and parts and i only work 1 or 2 days a week now because we are over stafed but thanks for the idea
No, I ment to spell it like that.
Look how close the e is to the ` key..........*runs and hides*
edit - My sig ownz so much, I just had to add it.
Cammy.....IAC valve is located in the same place on 3.1's, but it's designed different. Look at your throttle body, on the passenger side, where the other photo shows. There should be a little thing sticking out of your throttle body sideways...it has a clip going from the bottom into it, and two Torx screws holding the unit down. That's it. Just unhook the clip, and remove the two Torx screws and it wiggles/slides out..although it's in with an O-ring and if the O-ring is old and deteriorated you might need to buy a new one to install it with.
Mike..that's alright..everyone makes spelling errors now and then. Except me. (6th grade school spelling bee champ..4th place county.)
:lala:
:lala: Thread Starter
Engine: 5.0L H.O.
thanks but i cleanded it off and all but my check enigen light still comes on when i sit still for to long
