throttle body bypass
Old Mar 13, 2003 | 07:07 PM
bes217's Avatar
Hey guys. I did the throttle body bypass mod on my car yesterday and I have got to tell you, I noticed a big difference in throttle responce. When I slammed on the gas from a standing start there was almost no hesitation at all. Whereas before there was a lot of hesitation. I have heard a lot of people on here saying that the throttle body bypass is not such a good mod to do, but I think that it was GREAT!!!! I just figured that I would let you guys know how it did.
Old Mar 13, 2003 | 07:28 PM
zigzag 420 211's Avatar
hey i just did it to mine but i havn"t really noticed a difference but hopefully when it gets warmer out i will
Old Mar 13, 2003 | 07:50 PM
bes217's Avatar
This morning when I drove my car it was fairly cold out and I think that since the air was not being warmed up, I got a better charge and therefore I was getting better power and response. Good luck with yours.
Old Mar 28, 2003 | 07:29 AM
903.1fbody's Avatar
TB Bypass
before you say do a search, i did, couldnt find anything. How do you do the TB Bypass Mod? what all do you need? if you could give me a link or some instructions. thanx in advance
Old Mar 28, 2003 | 08:37 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
https://www.thirdgen.org/newdesign/t...ntbypass.shtml
Old Mar 28, 2003 | 08:40 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
It's been hotly debated whether or not this really works for power...never tried it personally..but here:
bes...a better test is with it fairly warm out and the engine completely warm. Basically, in your normal driving environment. Colder air makes a HUGE difference since the intake charge is much colder, it's much denser as well. Throttle response goes up, acceleration goes up.
Edit: Damn you Dale, beat me to it!
Old Mar 28, 2003 | 11:02 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Old Mar 28, 2003 | 11:08 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
If nothing else, it cleans up some of the clutter under there, and eliminates a little unneeded weight. I don't see any thing about it that could hurt performance... that's why I did it!
Old Mar 28, 2003 | 11:33 AM
Hey, what ever floats your boat, I don't want to argue.
The air is just going to pick up the heat when it passes thru the intake manifold because all the water passages are going past up to the thermostat back to the radiator anyway. The reason GM has the throttle body heated is so that it doesn't freeze up the IAC and vacum lines in cold climates.
Old Mar 28, 2003 | 09:21 PM
bes217's Avatar
Well, I don't live in a cold climate so I guess that doesn't apply to me. It has been warm here the last couple of days NIXON, but my car is out of commision for a while. But, when I get it put back togethter I will tell you how it feels.
Old Mar 28, 2003 | 09:36 PM
Nixon1's Avatar
Lucky.. Florida weather has been so messed up. Hot, cold, dry, raining.. Every day it's a new f*cking season here!! It was wicked hot today without much humidity. Wonder if it'll rain tomorrow.. Hopefully it will AFTER I get to work. I have to install my new Blaster coil and charge my freon and take her out for a spin to see how it goes....I dont wanna try in the rain!
Old Mar 28, 2003 | 10:17 PM
Doward's Avatar
You're not kidding, man! New friggin' season every day. Lets see how tomorrow is...
Old Mar 29, 2003 | 08:50 AM
Nixon1's Avatar
Bright and hot here today.... I'll have to see if I can't get my dad to back out of the garage and let me use it. Nothing worse than working under that sun..it's a killer.
Old Mar 30, 2003 | 11:25 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
yes it was great when it was a GREAT mod when it was my only throttle mod, i got used to when i could jump the tree, then i added my msd and it all changed, i got so much throttle response off the line now that i sit there a spin for a couple seconds, when i was installin my DZ springs i compared tyres and was like OMG there aint no tread on this here tire so i swapped the one with tread with the one with our tread and now my car handles so differently cuz when i et it to lose the rear end that left tire has no tread so it slides to!
but my freind could feel the diff in response back when i did it, it cost me like 4.25$ for al the parts from pepboys
Old Mar 31, 2003 | 02:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've had it bypassed since '97, and living in NJ, we get some cold winters. Never had the TB freeze up. Engine heat conducted through the steel block/manifold should prevent that.
Old Mar 31, 2003 | 04:04 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I did a TB Bypass....added RAM AIR boxes....installed a 52MM BBK/Edelbrock TB....and installed a new Throttle Cable. With everything combinded...I noticed a huge difference....throttle response..is soooooooooooo much better. It really surprised me.....
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
