picture needed
Old Mar 26, 2003 | 08:04 PM
custom85's Avatar
Car: 1985 camaro
Engine: mpfi 2.8 v6 hopefully soon to be 350
picture needed
i am in need of a picture of the back side of an 85 mpfi engine bay
i figured out my vacuum problem but i dont think the brake booster is hooked up properly
thanks
Old Mar 26, 2003 | 09:47 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
brake booster hose goes to the big connector on the back of the base manifold.
Old Mar 27, 2003 | 07:23 PM
custom85's Avatar
Car: 1985 camaro
ok thanks one last question the tee on the back of the manifold on goes to the canister where does the other lead
Old Mar 28, 2003 | 06:47 PM
Engine: 5.7 / 7.4
my bad. I just looked at the hook up, and I have the brake booster going to the "T" fitting, and the pcv tube going to the base manifold fitting. not sure if it really matters, as I have plenty of brake pedal.
Old Mar 28, 2003 | 10:23 PM
KED85's Avatar
Old Mar 29, 2003 | 12:09 AM
Engine: 5.7 / 7.4
neat pic, where'd you get it from? :sillylol:
Old Mar 29, 2003 | 07:44 AM
custom85's Avatar
Car: 1985 camaro
ok if you have the pcv going to the base of the manifold where is the line from the throttle body going?
Old Mar 29, 2003 | 09:58 AM
KED85's Avatar
THAT BIG THICK PLASTIC HOSE GOES TO TB & MANIFOLD INLET & TO PCV. IT GOES UNDER THE TOP OF THE MPFI
That's why ya remove the TOP to do the WORK!
ALL ya gotta do is as I suggested so it is a simple mission.
Do you NOT have that thick plastic hard line hose?
I AM SO GRATEFUL FOR THAT HOSE ROUTING PIC!
I can't tell ya how difficult is was to figure out the PCV set up, yet, by JUST DOING IT, it was so BLOODY SIMPLE! IT ALL FALLS INTO PLACE
AND I was "working" with a a guy addicted to herion. Oh the joys!
Old Mar 29, 2003 | 10:45 AM
custom85's Avatar
Car: 1985 camaro
this would be very simple if i had the original lines but i dont thats why im asking all these questions that seem really dumb
Old Mar 29, 2003 | 12:26 PM
KED85's Avatar
QUESTIONS ARE NEVER DUMB.
This is the first time you've said you are MISSING some lines.
Last time I recall you said the lines were just not attached and you needed a way to figure out how to attach them.
That's what I've been working with from your past statements.
That big hard thick plastic hose line would should be easily available in a wrecking yard, as it can't be as easily damaged by engine heat.
Having gone to the GM dealer, I was informed that the lines no longer in the parts systems for purchasing.
And I know I suggested ya get to a wrekcing yard to see how to do this mission, anyway. Looks like ya have to score it from a yard and 1985 stuff is "unique" yet that large thick plastic hose COULD be on other years, also.
Need to finda car from 1985 to atleast 1987. After that 1987 year, the parts may really start to be different.
It is very different in the 1991-92 years.
Good hunting to you.
That plastic hose is UNDER the top of the MPFI unit.
Need a 10mm 12 point socket to do the removal job.
Old Mar 29, 2003 | 01:34 PM
custom85's Avatar
Car: 1985 camaro
ok i think i found my problem there is a metal line that runs from behind the throttle body to the egr and it has a huge crack in it
has anyone replaced this or know how much it is or if i can get one anywhere but the dealer
thanks
Old Mar 29, 2003 | 10:25 PM
KED85's Avatar
Don't you have any wrecking yards by you?
Get it there for free!
Unbolt, slip into pocket/socks/pants leg, done!
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Street Lethal
Aug 12, 2015 11:33 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
