we made a little modification (+)
Old Mar 27, 2003 | 09:47 AM
ZheKo's Avatar
We just changed engine, but injectors and everything (ECM, exhaust, manifolds) left from 2,8.
Old Mar 27, 2003 | 09:48 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
you might want to try that one again, I don't understand.
Old Mar 27, 2003 | 01:15 PM
ZheKo's Avatar
I mean (+)
We swapped broken 2,8 with good 3,1 without swapping all electronics, sensors, ECM, injectors, etc... Now i need to calibrate MAF sensor. I need a voltage, wich is going from the middle wire of MAF sensor (part N 25007557)
Old Mar 27, 2003 | 01:22 PM
ZheKo's Avatar
I mean (+)
Old Mar 27, 2003 | 08:36 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Welcome to the boards,
Swaping engines=lots of fun
What kind of fbody do you own? Camaro or Bird?
Old Mar 28, 2003 | 12:56 PM
ZheKo's Avatar
of course Camaro (+)
I have Camaro `85
Old Mar 28, 2003 | 06:29 PM
funstick's Avatar
you have a 1227870 ecm. it has $1f mask ID code. it should be ok with 17pph injectors but youll need to dial in the FP just a tad to get it to run. 17pph is the upper limit of what the stock programming can handle.
the 3.1 and the 2.8 use the same heads cam etc. so my advice is to tell you to go back to bascis. set the timming at 10* btdc. check for vacum leaks. then go forward. also to note you car has a FQ based maf sensor not a voltage based maf unless your maf orignially came from a v8 car.
6speedIROC
16
Mar 15, 2023 08:33 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
slowsi
Oct 18, 2015 08:49 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
