Help with Non-A/C, no smog pump belt routing on a 2.8L
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Hey all, were trying to bypass the A/C on Firebirdchk24's car because the bearings are bad on the pump. However, none of the stock size belts seem to fit. They are either too long, or too short to fit. We got a belt thats an inbetween size and it does indeed get tight, however it rubs against itself with the way its routed.
We have routed it the correct way according to the panel over the radiator. Here's a pic of where its rubbing.
Sorry, my server is down, I'll attach it in the following post.
well it looks like the most logical thing to do is get a working used compressor have Tim help me recharge it so it will work since he has the tools and that means live with the noise for awhile and return the belt tomorrow afternoon...so i'll be squealing down the road for awhile
but oh well at least it runs
I think you and I need to put together a list of all the things that need to be fixed on all of our cars combined and just do it in one weekend. ^_^
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
When my compressor was squeeling i sprayed tons of WD-40 in it with the car running and the ac off then when the ac on then with the car off and i jsut kept repeating that and it went away this was 3 years ago and i still havent herd it come back.
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
You might want to try one of these- its an A/C Delete pulley that is for the TPI Camaros. Part# 10055890 from any GM dealer, cost aprox $40. It will work on our cars, we run the same Harrison A/C compressors as the V8's.
Well, 9d1burd, firebirdchk24, and I talked and we're just going to get a new compressor and charger her a/c system. It'll most likely be cheaper that way.
I'd recharge my A/C system, but I don't have the cooland bypass valve, and my heater core isn't even hooked up. Why is it called a heater core if it cools and heats...? j/k, don't answer that.
Moderator/TGO Supporter
Car: 1997 Z28
I have never seen that pulley before, thanks for the tip. I assume that means your stock length belt is still useable?
Yeah, i think we convinced her that a new compressor is the way to go, Ac is always nice to have.
1992 Trans Am
May 10, 2023 07:19 PM
mcquigg
Aug 13, 2015 02:26 PM
