Fender Removal Question
Old May 4, 2003 | 03:27 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Removing the passanger side fender here... I've got all the bolts out, but I'm not sure how the radio antenna wire comes off the fender! I see it running up the brace... how do I remove the wire to get the fender out?
Old May 4, 2003 | 03:43 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
ahh the fender removal king is here
i had to replace both fenders, hood, and the front nose
for teh passsenger side i just unscrewed the peice that goes over the fender hole and removed the atenae and pulled up over the rest of it, mine wasnt in a brace though in the fender
Old May 4, 2003 | 06:53 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
darn, I was hoping drivers side, I know how to remove it, not the passenger.
Might have better luck asking in the body/interiour section.
Old May 4, 2003 | 07:00 PM
Engine: 3.1
so many screws holding the fender on
pop the hood. lots of bolts running down the side holdin fender and hood on there.
lots of bolts holding fender to front nose,
and o yes dont forget the bolts under the side ground effect, that u have to remove to get too!
Old May 4, 2003 | 07:11 PM
Shok's Avatar
its been awhile since i have done that, i THINK you can get to the bolts for the brace if you open the pass side door and look inside the fender in the hinge area.
Old May 4, 2003 | 07:26 PM
Doward's Avatar
Actually, the black thing that holds it on was stuck. So I broke the whole damn thing off! I'm going to re-run my antenna up along the fender lip. Not sure if it'll pick up worth anything... but it might. And look a LOT cleaner
Old May 5, 2003 | 02:14 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Mine was stuck too when I went to pull it... I used a set of vise grips around it and it eventually broke loose. After that I undid the bolt on the antenna support and the whole thing slid down in, and off it came!
Old May 5, 2003 | 06:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What black thing? You mean the inner wheel well? Should be attached to the fender with plastic rivets... pull the center out with pliers, and the fastener comes out. I have an aftermarket antenna on mine; no lower support bracket. I re-used the grommet from the original antenna (power antenna) to feed the new coax through to the inside of the car.
The power antenna relay now does a new job; it gives my amps their turn-on signal. My radio just turns the relay on; it doesn't drive the amps directly.
Remember to re-align the fender to the door and the hood; don't just bolt it on. Otherwise you could ruin the paint of the fender, especially where the front edge of the door comes near it (when you open/close the door, the gap changes).
Old May 5, 2003 | 09:14 PM
Doward's Avatar
No, TomP, I mean the black thing at the base of the antenna, with 4 little grooves in it. It was stuck - spinning it spun the whole assembly. So I broke it down through the fender.
Old May 5, 2003 | 10:29 PM
Shok's Avatar
I think you can get a tool for that antenna nut at harbor freight.
Old May 6, 2003 | 10:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh; that piece! Yeah, it's a pain to grab with pliers. Eastwoodcompany.com has that tool too...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
