Somethings melting, eek
Old May 14, 2003 | 01:57 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
I went out and poped the hood on my 85 camaro and noticed that from the A/C compressor, the 2 hoses connected to it have a fresh burn spot in them and the hoses in the burn spot look melted. theres no belt or anything that could rub on them that i could see. Im stumped
Ill run out and get a pic of it.
Old May 14, 2003 | 02:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm just happy I guessed right that you've got an '85.
Does the A/C work (blowing cold air)? Just wondering if your a/c system is still pressurized with freon... if it is, I'd imagine if those hoses burnt thru, it'd be pretty explosive.
Old May 14, 2003 | 02:18 PM
Engine: 305 carbed
Axle/Gears: unknown
Im not sure if the AC works i havent tried it and im not sure if the system is pressurized. I really dont want to start it up and try the AC just in case it does burn thru and well you know.
Heres the pix of the spots
Old May 14, 2003 | 02:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
First thought- the compressor pulley slung some oil onto the hoses. (The metal plate over the top of the pulley is an oil splash shield) That would also explain the "smear" on the fuel pressure hose closest to the top of the a/c compressor.
Second thought- a belt snapped, and "bit" into the hoses. The previous owner replaced the belt.
Third thought- None of those would really cause a burn mark... did you ask on the general tech board?
Old May 14, 2003 | 03:29 PM
Engine: 305 carbed
Axle/Gears: unknown
Thanx for the ideas
Ill post this in the gen. tech also and see what comes up.
I did check the AC system and it does have pressure.
Old May 14, 2003 | 06:34 PM
Engine: 305 carbed
Axle/Gears: unknown
I went out there again and wiped away some of the oily mess and the lines look to be fine but the oil is like thick grease or something???
Old May 14, 2003 | 07:30 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Sounds like good ol' sludge. If the lines are fine, don't worry about it. Is the rest of the engine greasy? I'm betting a hunk of sludge hit the belt, and got slung on the hoses. Clean your engine compartment!
Old May 14, 2003 | 07:36 PM
Engine: 305 carbed
Axle/Gears: unknown
well i was told it was a bad clutch on the ac compressor and that it was slingin grease along with some freon on near by parts and when i went out there and tryed to turn the compressor it was hard as hell and it had the same grease crap on it.
Old May 14, 2003 | 08:20 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
those are fuel lines,so hope you dont burn through em
Old May 14, 2003 | 08:22 PM
Engine: 305 carbed
Axle/Gears: unknown
the 2 above the ones with the grease on them are the fuel lines. I went out there and it was just grease from the compressor that was flung on to the hoses.The lines themselfs look fine undernether the grease.
Old May 15, 2003 | 12:14 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Glad to hear it wasn't burnt hoses!
Old May 15, 2003 | 01:04 AM
Engine: 305 carbed
Axle/Gears: unknown
Me too.
Old May 15, 2003 | 09:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If the a/c compressor is causing a problem, you can always yank the drivebelt from it. If it's an old drivebelt (looks glazed and has cracks), you may as well just cut it with a knife and throw it away; then you don't have to take the other two belts off. And if all 3 are old, think about changing the belts soon...
db057
Apr 28, 2019 07:45 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
bryaniskoo
Oct 1, 2015 03:18 PM
corey8084
Sep 17, 2015 02:56 PM
