pulling the code?huh??
Old May 16, 2003 | 06:23 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
Ive been readin alot of these threads and have got ALOT of info off them but i keep seein the phrase "did you pull the code" and as im new to the whole computer fuel injection thing I have no idea what that means or how to do it. If anyone can shead some light on it for me id be very greatful Thanx
Old May 16, 2003 | 08:58 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
when the computer senses something wrong with the motor, it throws a code. This results in the check engine light coming on. if you turn the car off, jumper the 2 right most terminals on the top of the ALDL connector, and thurn the ignition to "ON," it will spit a code out by flashing the "Check Engine" light. You can find the ALDL connector on under the steering column, to the right hand side. Just stick a paper clip in the top right hand corner and turn it to on. You can find a write up of all the codes in the tech section of this site. It's normal for a car to spit out code "12," which means that there is no reference voltage at the ICM, that's because the car is not running. It's important that you do not start the car with the terminals jumpered as you will not get any codes, just turn it to "On." Hope this helps.
Old May 16, 2003 | 09:30 PM
Engine: 305 carbed
Axle/Gears: unknown
Yes it does, Thanx
I remember on a friends old K car that you had to flip[m this switch on the distrib. i think on and off a bunch of times then the Check engine light would do the blink thing
Old May 16, 2003 | 10:40 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Click here Click on Miscellaneous...first item on the page. Bam.
Old May 17, 2003 | 12:34 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
the blinks represent numbers. "blink" = 1 , "blink, blink" =2, etc.
Your check engine light will go "blink...... blink, blink" (hence code 12) 3 times before it displays a real code, and will do the same for each subsequent code until all are displayed. when all are displayed, it will go "blink..... blink, blink" all over again.
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
