Cooling fan switch?????
Old Jun 1, 2003 | 12:07 PM
spcjep's Avatar
I have a 92 camaro V-6 which has a problem with getting hot. The cooling fan comes on itermittently. I have replaced the coolant temp. sensor. I am trying to replace the cooling fan switch on the firewall. The problem is that there are two switches side by side facing the front of the car and one switch facing inward toward the engine. Which one is it - Passengers side, Center or Drivers side?
Thanks,
JP
Old Jun 1, 2003 | 07:21 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
switch I assume you mean relay??
I have 3 relays on the drivers side of the car. Fan is the middle one on mine (91)
It will also have a fat ol red wire going to it.
Old Jun 1, 2003 | 11:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Where are these switches? I didn't think the 3.1's had a fan switch. 2.8's fan switch is in the rear outer corner of the passenger side's head. 2.8's "idiot light switch" or "full gauges sensor" is in the front outer corner of the driver's side head (behind the a/c compressor bracket).
Old Jun 2, 2003 | 10:30 PM
spcjep's Avatar
Thanks for the help guys. The "switch" is a relay, I am sorry for the confusion. I have replaced the center relay which had the large red wire. The relays were located just inside the drivers side under the hood attached to the firewall.
I ran the car ant the fan seemed to work ... I will need a hot day. The top radiator hose got hot while the bottom one stayed cool....could I have a thermostat problem? The hottest the car got tonight was 200. Am I just neurotic?
Thanks for the advice
JP
Old Jun 3, 2003 | 05:47 AM
Dale's Avatar
Engine: 350 S-TPI
200 is not a bad tempature. Stock t-stat is 195deg.
Old Jun 3, 2003 | 05:41 PM
spcjep's Avatar
At what point should I get worried? About 220 or 230?
Thanks!
Old Jun 3, 2003 | 07:52 PM
Dale's Avatar
Engine: 350 S-TPI
Your stock fan doesnt come on tell 220. So in gm's mind, thats fine. I would say 220-230 I would start to be worried.
Old Jun 3, 2003 | 09:38 PM
spcjep's Avatar
Thanks, I will keep an eye on it!
JP
Old Jun 4, 2003 | 10:26 AM
mvftw's Avatar
I hot wired my fan to a toggle switch under the lights ****...225* was too hot for me...once it goes over 200*, I hit the switch, back to 190* in minutes...
Old Jun 4, 2003 | 11:24 AM
Dale's Avatar
Engine: 350 S-TPI
mvftw, thats next on my list.
Old Jun 17, 2003 | 09:34 PM
spcjep's Avatar
MVFTW,
How hard is it to put a toggle switch in for the fan? Can you give me the steps? Or is it easier to get a hypertech ... ( I forget what) that kicks it on earlier?
JP
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
