Question from a newbie
Old Jun 1, 2003 | 05:24 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
My car is an 1989 camaro Rs 2.8l V6 this stupid thing cant even chirp the tires. So I am thinking about converting to a T-5 tranny. But for now I am going to add a dynomax superturbo exhaust and thats all that I can find for the 2.8 engine. Can you guys help me along trying to find bolt on accessories that can give me alittle more power. Are the any headers out there for this engine. My future plans for the car is a 327 V-8 swap with around 380hp. i don't want to go into the V6 engine I.E. cams, intake manifold, etc..Do any of you know what it takes to do this V-8 conversion. any help is appreciated.
Old Jun 1, 2003 | 06:49 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Welcome to the board.
Just click on the search button to your right. There are tons of posts on V-8 swaps etc.
Headers, no comapny makes them, so its either E-bay, or some guy makes them. Once again use the search.
Old Jun 1, 2003 | 07:32 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Honestly, if plans are a v8 later. I wouldnt invest to much money in the v6, that wont swap to a v8.
I wouldnt even waist time/money dropping a t5 in, cause it wont swap to that v8.
Cat-back will swap, and ignition coil, ICM, dual fans, then start working on supsension stuff tell its time to work on the v8.
Old Jun 2, 2003 | 11:41 AM
Car: 89 camaro RS
Why wouldn't that tranny bolt up to that engine. Lakewood makes a bellhousing that fits 58-80 small block chevys. If it is a matter fof strength then I will get a set of G-forces new gear sets.
Old Jun 2, 2003 | 01:00 PM
Dale's Avatar
Engine: 350 S-TPI
Bellhousing on my T5 for my s10 is part of the case. Not changeable. I thought the one for the camaro was same.
Old Jun 2, 2003 | 01:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The header message is the third one down from the top of this message forum- https://www.thirdgen.org/techbb2/sho...hreadid=160965
Old Jun 2, 2003 | 03:31 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Most T5 transmissions have a separate bellhousing. The problem doesn't come from the bellhousing, or even the gears really (though they'll shatter just as fast), but the input shaft itself. Doesn't really matter anyway, though. With that kinda motor you're likely to nuke even a TPI car's T5 in no time. They're just not rated for that kinda power (seen a stock L98/T5 combo lately?).
Old Jun 4, 2003 | 12:00 PM
Car: 89 camaro RS
Well what about a t-56 tranny will it hold up to the power.
Old Jun 4, 2003 | 12:53 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
it will but T56s are still kindda expensive but if you got the cash then go for it
Old Jun 6, 2003 | 01:44 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
If you just want to chirp the tires with the engine you have now...try Tomp's tune up first if you haven't already and maybe some decarbonizing if the tune up doesn't help. I know there are posts about both of them.
I don't really know if you'll be able to chirp them after you do those things since my engine runs on about 4 and a half cylinders but I would guess you could.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
