My car idles at 1200 RPMs, is there something wrong?
Old Jun 4, 2003 | 08:02 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
When i start my car, the cars idle RPM on the tach reads about 1200 RPM, is this normal or is it too high? and if it is too high, what should i do?
Old Jun 4, 2003 | 10:25 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
does it stay there, or idle down after a while?
Old Jun 4, 2003 | 10:38 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
auto or stick? My '88 idles about 1k till warm, then around 800rpm
Old Jun 5, 2003 | 12:41 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Either your IAC motor is lazy and doesn't like to lose all the way, your TB needs a good cleaning, or you throttle spring is weak. Try cleaning the Throttle body with some cleaner, it's easy, just follow the instructions. This inclused removing the IAC motor from the engine, holding it with the point down and sprying it to clean off the surface. If that doesn't help, Try shutting the throttle plate by hand, ush it shut and see if the idle goes down. If it does, your spring is weak. I fixed that problem on my car by going down to pep boys, buying a $6 carb throttle return spring setup, and mounting it on there. If there still isn't any sign of resolution, replace the IAC motor. it's not very expensive(compared to some other things), only like $20-$30, and the problem should go away. If none of this helps, let us know, we can come up woth other ideas.
Old Jun 5, 2003 | 03:31 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Clean/check the battery terminals. It could be ECM in "battery mode": "...when battery is bad, ECM put the idle at high RPMs for voltage compensation... (or so)" = Chilton's manual for others cars.
Denis V.
Old Jun 5, 2003 | 08:18 PM
92RS3.1L's Avatar
Car: 91 Z28
It starts at 15, then it goes down to 12
Old Jun 5, 2003 | 08:19 PM
92RS3.1L's Avatar
Car: 91 Z28
It is an auto
Old Jun 5, 2003 | 08:20 PM
92RS3.1L's Avatar
Car: 91 Z28
Yeah, i definelty need to clean my TB, so i'll try it and see if it works.
Old Jun 5, 2003 | 08:21 PM
92RS3.1L's Avatar
Car: 91 Z28
Denis V.
I JUST replaced the battery, but i'll check
Old Jun 6, 2003 | 06:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Then you need to do the idle learn procedure. The ECM lost this information when you replaced the battery. A search for 'idle learn' and RBob will find the procedure.
RBob.
Old Jun 6, 2003 | 07:24 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Tap the gas pedal to spike the rpms up to about 1800 or so and release it real quick. Watch the tach. It should idle down, then sit at probably around 1000-1200 for a second, and then drop back down to normal. Tapping the gas like that takes the computer out of 'warm up mode' or whatever it's really called....and it brings the throttle back to minimum idle. NORMALLY, that is.
Old Jun 6, 2003 | 09:03 PM
92RS3.1L's Avatar
Car: 91 Z28
Ok, ill give it a try
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
killer777
Aug 8, 2015 02:47 PM
