bad starter ?
Old Jun 9, 2003 | 11:39 AM
92 RS JD's Avatar
bad starter ?
I put a new starter in but sometimes when i start it it just clicks is this a bad starter
Old Jun 9, 2003 | 05:00 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
did you replace the solenoid too? If not, that could be your problem. It's the little thing that looks like a motor kinda piggy-backed onto the starter motor itself. I know they sell them seperately, so you might not have gotton it and had to use the old one.
What happens in a starter is when you turn the key, the solenoid pulls back, this actuates a fork that engages the starter gear. When the solenoid pulls, it also makes a set of contacts(kinda like a relay) and send power to the starter motor itself, that's what makes it spin. So you see, if the contact in the solenoid is bad, it won't power the motor. Also, Just check to see if the big copper starp connecting the starter motor and solenoid is tight. if not, you aren't sending power into the motor.
bbsr72
Sep 27, 2015 05:55 AM
FormulasOnly
Sep 10, 2015 09:07 PM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 03:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
