Can't get cool air
Old Jun 14, 2003 | 09:36 PM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
Can't get cool air
Hi Guy,
I am the Taiwanese with the Firebird V6, the working temp is higher than my Grand Am 93, so the temp inside the car is pretty high too, the car already added 2 more fans but they said that there is no cool air come in when driving beacuse there is no hole in the front(either hood and bumper), how do you guy fix this problem except the ram air hood modify.
Thank you.
Joe
Old Jun 14, 2003 | 09:40 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Look under your car. There should be a "fin" running along the length of the front of the car under the radiator. A lot of tmes, that gets ripped off, and you'll need a new one - it pushes air up and into the radiator from under the car.
Old Jun 14, 2003 | 10:58 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
In case you need one, its called an air dam.
Old Jun 14, 2003 | 11:54 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
beautiful drawing mike the purpose of that lil' black piece of plastic is to deflect air up on the radiator and over the engine, thus cooling the car's engine bay slightly (alot). So , if it's missing get it, check bone yards and whatnot, the piece is actually a 3 piece setup, 0ne piece in the middle ot deflect the air up, and the other two on the corners deflecting air around the car instead of under neith the undercarriage.
Old Jun 15, 2003 | 12:01 AM
Doward's Avatar
Odd... can't say that my Camaro has the side ones. Are the Firebird only?
Old Jun 15, 2003 | 10:35 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yep...only Firebirds have the 3 piece. Camaros had the one piece center one.
EDIT: Well I probably shouldn't say ONLY....but I will say that I have NEVER seen a Camaro with a 3 piece...only Firebirds...not many at that! My friend's 84 T/A had a 3 piece.
Old Jun 15, 2003 | 10:42 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
my 90 firebird looks like its got a one piece air damn, but i never really looked at it in detail.
Old Jun 15, 2003 | 01:12 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
My birds air dam looks somehting liiek this .. the black part is one piece but the parts that hold it in are three
Old Jun 15, 2003 | 05:24 PM
85f-bird's Avatar
Engine: 2.8L, LS1
yep, mine looks like skates, never noticed that they were firebird specific on the three piece model though, huh. Also, a lot of mid gen T/A's that i've seen have the one piece camaro styled air dam. Actually, i'm only running the middle piece right now on mine because i had just recently put the t/A ground fx on the car, but the sides will be going back on as soon as i can get a lil' bit of time...ooh, got a lil bit of time right now.
Old Jun 15, 2003 | 11:06 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Here is mine on my Camaro.
Old Jun 16, 2003 | 09:59 AM
Nixon1's Avatar
Hey...what in the heck is that red bar running between your radiator and front sway bar? Some kind of bracing??
Old Jun 16, 2003 | 10:05 AM
Engine: 346ci LS1
Transmission: MN6
GM IROC Wonderbar (yes I know, I think Wonder Bra every time I write it! lol) and it's powdercoated red.
Old Jun 16, 2003 | 10:12 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I guess I installed my bar backwards, my "lips" are pointing down.
Old Jun 16, 2003 | 10:18 AM
Nixon1's Avatar
OHHHH...so THAT's where those go. That's a brace for your steering box to keep it from cracking, correct?
Old Jun 16, 2003 | 10:41 AM
Engine: 346ci LS1
Transmission: MN6
I honestly don't think it matters either way.... It's still added strength.
No, there is steering box brace is a different part. If I remember they are a rare part to find, but that is something I might get. I think AGood2.8 has one or I would think he would considering he's into auto-x'ing.
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
