Dissapearing Fluid!
Old Jun 23, 2003 | 04:34 PM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
Dissapearing Fluid!
yeah, this sounds weird, but ill top off my coolent to the "hot" line(when the car is hot) in the resivour, and withina few days, it's under the cold line.... when the car is hot.... im not seeing any leaks at all, please help
Old Jun 23, 2003 | 05:37 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
when the car is cold take your hands and run them over every part of the cooling seystem you can touch, if it comes out dry you may have a bigger problem.
start your car, let it run until hot (go get a slurpie or somthing) and then while car is still running put your hand right up to the exhuast. hold it there for a few seconds, if your hand is moist, damn, you have a broken waterjacket or head gasket, big trouble. pray that you just have a split hose.
Old Jun 23, 2003 | 06:36 PM
Ovrclck350's Avatar
Is your oil milky?
Old Jun 23, 2003 | 10:51 PM
Engine: 2800
....but im not having an oil problem... just changed the oil after 2100 miles, still kinda clear acctually, wouldnt a blow head gasket cause a loss of power or somthing? cuz thats not really a broblem, what kind of deal is it to have a busted a water "jaket" ? or is that your water pump.... thanks guys
Old Jun 23, 2003 | 10:54 PM
Engine: 2800
also.... there is a brownish film inside my fluid resevoir.... also, i moved it across the engine bay, where the washer fluid resevoir was.... (86 2.8) thanks.....
Old Jun 24, 2003 | 05:48 AM
Xophertony's Avatar
Axle/Gears: n/a
i bealeave the water jackets are the lines in your block that water travles through, if one is busted, water will leak into your cylenders and be burned with fuel causing moisture in your exhaust...
Old Jun 24, 2003 | 06:10 AM
Engine: 2800
holy sh$#..................... this is not good......... but i mean, i just had the car in the garage yesterday.....( it made a POP and died on the road, i took it in and they said nothing was wrong with the car....) i wish i could hear an alternative to this devistating news....
Old Jun 24, 2003 | 06:58 PM
Engine: 2800
allright.... did the runing my hands over the rad. lines, it squished and squashed its way thru, i could see it running in and out of the resivor, didnt get that much back but i poped the radiator open, and the fluid was almost to the brim inside the radiatior... maybe theres a clog in the return lines somewhere? i really dont think its somthing as serius as what im afraid of.... cuz the oil is clean, and no power loss or strange sounds, thanks alot guys... need to get this fixed b4 i can throw in that nice little shift kit ya know?!!!!!!
Old Jun 24, 2003 | 11:36 PM
socialdeviant's Avatar
there is a pot metal fitting on the bottom of the manifold, under the TB.
If you look at the passanger side of the engine, you will see a 5/8" black formed tube that bolts to the engine, and runs back under the TB.
between the black tube and the manifold is the fitting. it will most likely break as soon as you touch it, it's like 8 bucks at the dealer The dealers around here knew exactly what I was looking for whenI went in, but that might not be so near you. Ask to look at the screen and point out the fitting to them.
Be prepared with a tap and dir set the size of the fitting, you will more then likely need it.
Old Jun 25, 2003 | 03:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I would say to look at your engine when it's HOT. When the car's cool, the cooling system isn't under pressure. It's when the coolant's hot that the whole system is pressurized. A tiny pinhole in a hose that doesn't leak when the car's sitting might turn into a little geyser when the car's hot.
I had a leak like that once; in one of my heater hoses. I was losing coolant but didn't know why. Popped my hood one day after driving, and saw steam- my exhaust manifold burnt a pinhole into my heater hose. Coolant was spraying in a thin line onto the exhaust manifold and evaporating. It didn't do that when the car was cold.
The brownish-bit of the antifreeze is probably just old rusty antifreeze, that's all. Combine that with crusty white deposits from using regular water for the 50/50 mix (and not distilled water, meant for steam irons), and you can get a funky looking overflow bottle.
Old Jun 25, 2003 | 06:40 PM
Engine: 2800
found a small crack in the fluid resivour... could that be it??? i ciliconed and duct taped the sh## out of it.. but like you said tom, it was cold no pressure, that shoud hold me over untill i get i can snag another resivour... (can i get one from a parts store or do i need to go to a junk yard??) thanks ...
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
