bigger injectors
Old Jun 25, 2003 | 03:54 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
bigger injectors
Hey, I am trying to find out what I would have to do to install 19# injectors in my 3.1L engine. I tried just putting them on the fuel rail, it ran but not very well. Seemed the timing was off or something.
thanks
Old Jun 25, 2003 | 06:27 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
It is now running too rich. You need to recalibrate the PROM.
Old Jun 25, 2003 | 06:29 PM
mmcdjs's Avatar
Engine: 3.1 V6
prom
Ok.. How or where can I get that done?
Old Jun 25, 2003 | 07:36 PM
Doward's Avatar
You can get it done? I'm not sure... I'm working on buying the equipment to do it myself. Ask Funstick... maybe he'll do one for ya, cheap like!
Old Jun 25, 2003 | 08:50 PM
mmcdjs's Avatar
Engine: 3.1 V6
email
Thanks! I'll have to check with him. I just found the GMECM edit program from Magnus, that's killer. Wish I knew what I was looking at though..haha
Old Jun 25, 2003 | 10:09 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
let me know if you can figure any of it out. i've got all the equipment for the prom burning but i can't figure any of it out. if anybody wants to help me....feel free!
Old Jun 25, 2003 | 10:25 PM
Doward's Avatar
YOU!! You have the whole prom burning setup?! Must meet up with you.... lol!
I'd be absolutely happy to help you out with prom burning, as it would benefit myself, being able to reburn proms now, lol!
Old Jun 26, 2003 | 05:45 AM
mmcdjs's Avatar
Engine: 3.1 V6
prom burning
Well heck, if you two can figure out how to do it,could you burn me one too?
Old Jun 26, 2003 | 08:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 3.1l SD systems ('90-'92) use the 1227730 ECM with the $88 maskid. When the injector size is changed there are two locations and a table of values that require updating. These values need to be changed by the same ratio as the injector size change.
The first two values below are double byte numbers. Keep this in mind when editing them as most editors only handle a byte at a time.
The table of values are single bytes so are easy to edit. Here you are:
Code:
; Idle fueling BPC
L86BA   FDB     0608    ; idle injector constant
; BPC for N-Alpha fueling
L871F   FDB     12288   ; math constant, (12,288) N-Alpha fueling
; Injector Constant vs. EGR airflow
; BPC
;       ;       BPC     ; airflow
L8754   FCB     182     ;   0
        FCB     179     ;  16
        FCB     176     ;  32
        FCB     173     ;  48
        FCB     172     ;  64
        FCB     167     ;  80
        FCB     162     ;  96
        FCB     160     ; 112
        FCB     158     ; 128
        FCB     153     ; 144
        FCB     151     ; 160
        FCB     151     ; 176
        FCB     151     ; 192
        FCB     151     ; 208
        FCB     151     ; 224
        FCB     151     ; 240
        FCB     151     ; 255
The values shown are from cal AZTY and may differ from what you find.
Another nice change is to eliminate the 'AFR drop with time in PE exceeds' parameter:
Code:
; PE AFR reduction term
L8B05:  FCB       0     ; 0, AFR reduction (was 1.0 afr), for above cts/mph thres
They kinda goofed with that one as it never resets. Engine gets real sloggy after a while. So I like to set it to 0 (zero).
For the ambitious there is a hac of the $88 mask on the diy-efi site (A hac is a source code listing). It is partially commented.
RBob.
Old Jun 26, 2003 | 07:12 PM
mmcdjs's Avatar
Engine: 3.1 V6
prom settings
Man, this looks cool, but I have no idea what it means!
Old Jun 26, 2003 | 07:14 PM
Doward's Avatar
Re: prom settings
He's basically saying ' YOu gotta change these two variables by the same ratio of old injector/new injector - the % difference'
Old Jun 26, 2003 | 08:45 PM
mmcdjs's Avatar
Engine: 3.1 V6
stock size
Well.. that's another problem. I have no idea what the stock size injector is. I've contacted lots of parts stores and even the GM parts sites and they can't tell me either. but what variable do I change
Old Jun 26, 2003 | 09:22 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
2.8 13
3.1 15
3.4 17
thats for FBODYS
Old Jun 27, 2003 | 06:44 AM
mmcdjs's Avatar
Engine: 3.1 V6
injector size
Hey, can you tell me where you found that information? I had figured that the injectors were around 14's, so I was close. The 3.8 also came stock with 19# injectors.
Old Jun 27, 2003 | 09:06 AM
Dale's Avatar
Engine: 350 S-TPI
Alot of research, plus finding the formual for injectors which is...
(hp x A)/(# of injectors x .80)=rating
A=
.50 for naturally asperated engines
.60 for boosted engines
So for my car being a 3.1
(140 x .50)/(6 x .80)=14.583
Old Jun 27, 2003 | 08:04 PM
mmcdjs's Avatar
Engine: 3.1 V6
injector size
Yep. that's the same one that I found. Can you tell me where to get a PROM burned with that new information?
Old Jun 27, 2003 | 10:44 PM
Dale's Avatar
Engine: 350 S-TPI
A guy on here name "funstick" I belive has the equipment. Doward would know more info on that part.
I would love to learn how, but need "hands on" to understand it. Plus buy the equipment.
Old Jun 28, 2003 | 01:03 AM
Doward's Avatar
Yep, Funstick would be the one to talk to!
Old Jun 28, 2003 | 06:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For a good primer on chip burning go to the DIY_PROM board (here on TGO) and the very first sticky at the top has a link to Trax's intro article.
Trax (Tim) covers it quite well including equipment and such.
RBob.
Old Jun 28, 2003 | 07:16 AM
mmcdjs's Avatar
Engine: 3.1 V6
burned prom
I already contacted him. He won't do one unless I'm local. Anyone else do it?
Old Jun 28, 2003 | 08:11 AM
Doward's Avatar
I'd be happy to do you one, if I could get ahold of the equipment...
Old Jun 28, 2003 | 12:42 PM
mmcdjs's Avatar
Engine: 3.1 V6
prom burning
Doward,
Are you going to get with the guy in Florida somewhere that has the equipment and doesn't know how to use it and burn some PROM's? I'd glady pay for a PROM!
Old Jun 28, 2003 | 02:25 PM
Doward's Avatar
Yeah, we're talking back and forth... of course, he'd be first in line for a prom, since it is his equipment, lol!
Old Jun 28, 2003 | 02:45 PM
F585's Avatar
Hey dow your turbo kit is going to include a PROM right?
Old Jun 28, 2003 | 04:04 PM
Doward's Avatar
Absolutely!
Old Jun 28, 2003 | 04:13 PM
F585's Avatar
Kool cant wait to turbocharger my cardboard motor
Old Jun 28, 2003 | 04:37 PM
Doward's Avatar
LOL! yeah, it should be good... first tho, I have to finish the prototype setup.
Old Jun 28, 2003 | 05:09 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
hurry up!
i need you done before i get my motor rebuilt. (2 weeks... or less depending on how many days off i get)
As soon as i get my motor rebuilt, i was hoping you would be done so we can see how well it works, what problems you run into, (if any at all) what you used, etc.
Old Jun 28, 2003 | 06:10 PM
F585's Avatar
BTW Dow or Lee7 is it ok to give my ride a small shot of nitrous with the turbo I'm buying the nitrous kit along with my rockers in Aug. but if it cant support it I won't get it.
Old Jun 28, 2003 | 06:59 PM
Doward's Avatar
Hmm... I'm going to have my kit run 6psi. I'd say a 50 shot is doable, but you need to be sure of enough fuel when you hit the nitrous shot... the injectors I include in the kit will have enough fuel delivery for a 75 shot, I'm sure.
(24pph in the kit)
Old Jun 28, 2003 | 07:15 PM
F585's Avatar
It just keeps getting better and better.
Old Jul 1, 2003 | 06:08 PM
mmcdjs's Avatar
Engine: 3.1 V6
eprom files
ok, I've searched the web and bugged everyone that I could find for the correct ECU and BIN files. I think that I found them on the www.diy_efi.org web site. Here are the links
ftp://ftp.diy-efi.org/pub/gmecm/bins...0/730_atta.ecu
ftp://ftp.diy-efi.org/pub/gmecm/bins/1227730/azty.bin
Could someone please check to see if these are right? I have the files and the program to change them with, but I have no idea what I really need to change now. HELP! If anyone has luck with it can I get a copy of the modified files too? Remember that this is for a 1991 Firebird 3.1L V6.
thanks
Old Jul 1, 2003 | 06:27 PM
Doward's Avatar
TunerCat is the easiest software I've seen yet to use to modify the bin files... you may look into that!
Old Jul 2, 2003 | 07:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: eprom files
thanks
I took a look at the atta_730.ecu. It is for the $A1 mask (Corsica's and such). Best bet may be to make an .ecu for the locations that you'd like to change.
The azty.bin is correct for your year and an automatic trans (not for a stick).
I do know that TunerCat supports the $88 mask. May need to request the three locations above be added to the .tdf file though (which they will do for you).
RBob.
Old Jul 2, 2003 | 07:29 AM
mmcdjs's Avatar
Engine: 3.1 V6
eprom
Well, do you know of anyplace that has the correct ECU file for my car? I'll contact tunercat and see what they say about it too.
thanks for the help!
Old Jul 5, 2004 | 02:22 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
This post alive
He,
So, if I change 13.5 injectors for 19lbs, then I must increase in 41% the following address in the PROM:
1.- Combinated 6BA/6BB
2.- Combinated 71F/720
3.- Each Singles from 754 to 764.
I'm right for $88 mask?
Thanks for any reply,
Denis V.
Fronzizzle
Feb 9, 2017 09:31 AM
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
87hellbird
Sep 14, 2015 05:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
