Why is she bogging down and stalling?
Old Jun 27, 2003 | 08:37 AM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Hey guys i got some problems with my car ... she keeps stalling, i could be driving and all of a sudden she'll bog then stall then the check engine light goes on but i cant get a code because as soon as i turn the key off it goes off until she stalls again.
Heres what ive change w/ no help
All the intake plenum gaskets
valve cover gaskets
did an oil change
changed the oil filter
changed spark plugs
and tryed that fuel injector cleaner twice
i think i may have gotten a piece of plastic in the intake tube that may have been sucked into the throttle body i dunno. And my air filter is really bad and needs changing but that cant stall it that bad can it?
Help.. 85 2.8 MPFI
Old Jun 27, 2003 | 07:51 PM
Well i think i may have found it .. my alternator died tonight it was probably kicking the bucket while making her stall
Old Jun 28, 2003 | 12:51 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
hopefully that's ur only culprit, but as i understand a failing altenator will drain the battery...so i'm not to sure, especially if it starts right back up....keep us posted if ur problems continue, by the way, the only reason u were getting a code when the car stalled is because the engine is dead and the car is in the on position...same thing you'll get when u first go to start the car, so that's normal.
Old Jun 28, 2003 | 12:59 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Look in the Tech Articles for pulling your code... you need to ground the diagnostic terminal of the ALDL connection, and then put your key in 'run' and the codes will blink to you.
Old Jun 28, 2003 | 02:05 PM
$110 later she still stalls on me but the battery doesnt drain itslef. It acts like all fuel stops going to the engine for a second and then it dies. really annoying especially stalling while moving in traffic
Old Jun 28, 2003 | 02:42 PM
pulled the code .. its a 34 MAF sensor
I pulled the little ****er out and it looked new and had a remanufactured sticker on it. Ahh well anyone know where to get one nice and cheap
ahh .. searching the boards i found someone else had the same problme and it was their pcv valve .. i remeber breaking and jerryrigging that back together two weekends or so ago. Im gonna replace it to check to see if thats it
Old Jun 28, 2003 | 04:08 PM
Well the new pcv valve helped a little bit but she did stall again and threw a code 34. Umm i cant afford a brand new maf how can i test the ones in a junkyard? I have a multimeter to do the testing w/. I cant be wasteing money ya know? .. Thanks
Old Jun 28, 2003 | 11:19 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
I feel ya man, mine does the same thing, but it'll only do it when i'm stopped and in gear, it'll idle allright, then it'll like hiccup and throw a code 34. I also get a code 44 sometimes. And I get really crappy mileage. if you figure it out, let me know.
Old Jun 29, 2003 | 12:12 AM
Doward's Avatar
Just go to the junkyard and try one out. Get a later model one, or if the dash is still in, look for a lower mileage one. Those are your surest bets for a good maf. You have to have one from a V6, if I'm not mistaken - different type MAF
Do you hear any hissing noises from the engine with it running?
Old Jun 29, 2003 | 12:23 AM
Engine: 4G63T
you can also use the maf out of most fwd 3.8 cars, it's the same, i know, i tried one.
Old Jun 30, 2003 | 02:11 PM
hey guys i changed the two fuses on the passenger fender with no avail and i think i found the MAF relay .. could that be the culprit?
Old Jun 30, 2003 | 02:53 PM
Hey guys .. i unplugged my MAF and took it for a ride, i got a check engine light but she didnt bog or stall at all. Can i safely say my MAF is to blame?
Old Jun 30, 2003 | 03:15 PM
Engine: 4G63T
you can use the gm book method to test mafs, with the engine running, tap the MAF with a wrench in a couple places and see if you engine sputters.
if so than it's definitely the sensor
Old Jun 30, 2003 | 03:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Diagnosis already says it's the MAF (ran fine while MAF unplugged); when you get a junkyard one, check a few things:
1) electrical contacts for harness plug aren't corroded or cracked
2) housing of MAF isn't cracked
3) orange frequency film (visible by looking inside MAF tube) should be completely flat- no wrinkles, no bends, no curves, nothing- perfectly FLAT!
You could also buy a rebuilt MAF, just make sure you spend the extra $20 or whatever to get the one with the lifetime warranty. I did that; I've been running on mine since '97!
Old Jan 6, 2006 | 02:38 PM
outcast45's Avatar
Car: 91 Camaro
Engine: 305 TBI V8
PROblem
First of all I just wanna say this site is great! and I am having the same damn problem! So gonna go buy a PCV valve tonite and go the junkyard tomorrow for the MAF sensor. I dont know what could be next, I guess spark plugs and wires but i just replaced them with AC delco ones....
Old Jan 19, 2006 | 05:31 PM
jasonsknight2k's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8 V6
This maybe a stupid ? but what is the MAF anyone have a picture?
Thanks guys!
Knight75
Old Feb 5, 2006 | 01:30 PM
drdroopy's Avatar
Car: 1991 Firebird
Engine: 3.1 V6
sounds like the same problem i had awhile ago, took awhile for me to figure this one out, i replaced every sensor that had to do with my ECS, even my computer, also tried plugs, wires, cap rotor, fuel filter, in the end it turned out to be a bad injector.......
try checking youre fuel pressure first to make sure the fuels even making it that far
Old Feb 5, 2006 | 01:51 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Thanks guys!
Knight75
MAF = mass airflow sensor. Follow the intake from the throttle body... the MAF is an inline sensor a few inches long with a wires coming out .
Old Feb 5, 2006 | 03:19 PM
daves12secV6's Avatar
dont waste ur time with junkyard maf's autozone sells reman one so dirt cheap with 1 year warrenties its not worth the trouble of searching the junkyards for one
Old Feb 5, 2006 | 03:46 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
anyone else notice how old this thread is?
Old Feb 5, 2006 | 04:02 PM
lmao i didnt look before
RedLeader289
May 28, 2019 01:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
