3.4 ?
Old Jun 29, 2003 | 07:34 PM
E-Z Rollin's Avatar
3.4 ?
Can a 3.4 out of a camaro/firebird be refitted with a MPFI and dist. from an earlier camaro/firebird with a 2.8 ?
Old Jun 29, 2003 | 07:37 PM
92CAMRORS's Avatar
I'm not sure about the distributor, but the 3.4 is essentially the same as the 2.8/3.1, if I recall. Never had one though, but I think it's basically the same block.
Old Jun 29, 2003 | 07:39 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yes and is done quite a bit. Search on here and find tons n tons of info about it.
Main ones that know this info..
Ked85
Project 85
Myself
Then their are 2-3 others that have done it.
Old Jun 29, 2003 | 09:53 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
on pg 1 of my cardomain site, you can see the 2.8/3.4 in various stages. I have more I can e-mail if you want.
Old Jun 30, 2003 | 11:10 AM
KED85's Avatar
Here's what ya wanna see.
This example is my 1985 Blazer set up.
It's "same" as your idea as I did that to my Firebird 3.4!
5 words or less.
All ya do is swap stuff in the end!
It's DETAILED
Yet extremly simple.
Read my Swap Boogie thread and enjoy the research.
I'm up to about 40+ people whom I've coached
Next response has after shot.
WHAT YA SEE is what comes from factory on the 3.4 the PLUG!
Attached Thumbnails 3.4 ?-blzng-20bolt-20d-20distb
Old Jun 30, 2003 | 11:15 AM
KED85's Avatar
After.
PS rebuild your distributor before you reassemble the engine.
Look for my distributor rebuild thread, also!
Hope this clears up your question.
Enjoy the research!
OH YES so worth the powerful results.
And my 3.4 Firebird runs so clean I have one CA SMOG test reading at ZERO!
I ONLY do smog legal swaps and works so great!!
Attached Thumbnails 3.4 ?-blzng-20bolts-20c-20dist
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
87CamaroLT
Apr 23, 2001 09:32 PM
