Stock coil voltage
Old Jul 13, 2003 | 02:25 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Stock coil voltage
What's the stock coil voltage for the 2.8? I just bought a 48,000 volt MSD coil that I will put in next weekend. I also bought a brand new distributor with a new module. That's gonna be awesome.
Old Jul 13, 2003 | 10:51 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Stock is 38,000V
Hypertech makes a direct bolt-in coil w/ 53,000V
Old Jul 13, 2003 | 11:47 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
is this really beneficial on a stock engine without upgrading the module as well? will a stock cap/rotor/wires be able to handle an aftermarket coil?
Old Jul 13, 2003 | 01:06 PM
I don't believe it really matters what module you have, but in any case I have a brand new one on my brand new distributor.
Also, I believe TomP said that Delco plugs will stand up to the higher voltages of after market coils, so that's what I got. I'm not positive that's what he said, but I'm sure he'll wander over to this thread and tell us all we need to know.
Old Jul 13, 2003 | 01:23 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
No doubt that the wires and cap and rotor and all should be able to handle the extra voltage...as long as they're in good shape. If the cap and rotor terminals are corroded...then this will of course reduce your ignition's power by the time it gets to the plugs. Same with the wires...if they're old and toasted out. In what I've seen, replacing a worn cap and rotor will generally make a bigger difference than replacing decent plugwires with high performance ones. I put my MSD wires on and barely noticed a difference. Put the new cap and rotor on and the car idled smoother and the throttle response was better.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
Thirim
Aug 13, 2015 03:09 PM
