Representing all the v6's
Old Jul 16, 2003 | 09:08 PM
Erin91RS's Avatar
Car: 91 RS
Transmission: 700-R4
i won the local camaro/firebird car show tonight! woohoo! Who would of thought my little v6 would beat out about 20 v8's/. Yeah the show was super small and they probably took pity on me for bein a girl and having a v6 but heck yeah! i won baby! hehe. Sorry I had to brag, this is the 1st show I won lol.
To keep this post techinical, is there any trick to loosening the bolt on my distributor? I need to adjust my timing back to 10 degrees and I can't seem to get to the nut. Any suggestions?
Old Jul 16, 2003 | 09:12 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Got two options....On my v6 there was a 5/8 bolt so i couldn't use the normal L wrench they use for pulling distributors...(they usually come in 9/16 and 1/2). Check to see what size your bolt is and use the L wrench if possible (AUtozone/O'reileys should have it, it should be labeled distributor wrench).
If you have a 5/8 bolt, your gonna need something called a crow's foot that hooks on to a socket extension, get a universal extension with it so you can swivel the wrench a bit. You can buy the crow's foot at sears for like $7, basically its an open ended wrench with a hole for the socket extension....good luck.
Old Jul 16, 2003 | 09:19 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Re: Representing all the v6's
Get yourself a big strong boyfriend to do your dirtywork, this way you can still be a lady and look as good as your car Congratulations on the trophy win.
Please note that I am trying to sound like a gentleman and not a male shovinist-
Old Jul 16, 2003 | 10:06 PM
socialdeviant's Avatar
as far as the distrib bolt situation...
I went ahead and got the 1/2" zig zag bar, and a cheap 5/8 shallow socket and welded it onto the zig zag bar. a little fine tuning (bending here and there) and it works great.
Good job on the win too...
Old Jul 16, 2003 | 10:47 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
you can get it out by unpluggin the wires that go to the distrib from the coil, then using a 3/8in drive and about 9 in of extension with a universal joint and the correct socket
then once u get it out u can do like i did and grind it down to being 1/2 in
then u can use that L-wrench...assuming u have one
awesome on the win....do u have any pics so we can see what it takes?
Old Jul 16, 2003 | 11:43 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
are you kidding me? there is absolutely nothing hotter than a girl doing her own work on her own car that wins competitions on her own! way to go girl!
Old Jul 17, 2003 | 12:35 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
to get my distributor bolt i just use a 15mm socket w/ swivel and extension, works great.
Old Jul 17, 2003 | 01:16 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Sorry partner, but I don't find it sexy in the least bit if my wife were to work on her own car and get all cut up and greasy- Whens the last time a woman had sex with you when you when you had motor grease all over your hands- Think you fantasies through better then talk to me.
Old Jul 17, 2003 | 05:29 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I used a 15mm wrench, shortty style that wal-mart sells for 10 bux. It was a pain to break loose, but once it was loose, it was easy going.
Congrats on car-show. I was pumped the first one I won also.
Old Jul 17, 2003 | 09:55 AM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Re: Re: Representing all the v6's
Awesome! Congrats!
<---- Available and from Ohio!
Old Jul 17, 2003 | 10:04 AM
BitchinRS's Avatar
Go to a real parts store. No Kragen, Auto Zone or Pep Boys. Go to a indepent parts store. Ask for a 15mm Distrib wrench for a 2.8 or 3.1. Same wrench, but depending on the manufacture it will be listed for a 2.8 or 3.1. They will most likely have to order it, but it is worth it. Makes the job so much easier!!!! I paid $28 and guard it with my life! I spent 1 and 1/2 hours with the parts guy going through catalogs looking for the thing. It has more bends then the L wrenches they use on V8's and clears all of the crap including the ignition model.
When I get home tonight I will see if there is manufacture and part number on mine. I can't remember who makes it.
Old Jul 17, 2003 | 01:41 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
Sorry it double posted for some reason
Engine: 305 carbed
Axle/Gears: unknown
when i tore my 2.8 down i used a think it was a 5.8s socket and a universal joint(knuckle) with a ratchet, Worked out perfect,
Hope it helps
And Congrats on the win!!
Old Jul 17, 2003 | 01:50 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I believe my distributor bolt is 15mm, and I haven't found an L-wrench of that size. I like to use a combination wrench and come in from the side... severely burning my hand in the process.
Old Jul 17, 2003 | 02:02 PM
Engine: 305 carbed
Axle/Gears: unknown
Yea that was it, 15mm, i remember now cuz it took me half the day to find it lol
just use the 15mm socket and a U joint with an extention or 2.
Old Jul 17, 2003 | 05:30 PM
Erin91RS's Avatar
Car: 91 RS
thanks guys. My boyfriend has all the tools but he's just having one heck of a time getting to it cuz there is a cable in the way. As for working on the car, I just wanted to see if can do it myself. Sorta like a learning experience. I don't mind getting a little dirty sometimes lol. thanks again!
Old Jul 17, 2003 | 07:33 PM
Dale's Avatar
Engine: 350 S-TPI
Go for it girl, give it a try. If hes good with cars, he can fix about anything you can mess up.
Black86, I think she just blew your bubble, but I think it was a good try
Old Jul 17, 2003 | 08:10 PM
icebird_1981's Avatar
congrats on the win
but it dont matter what engine u got in a car show its all based on looks. so u won because u take care of your car, keep up the good work.
Old Jul 18, 2003 | 10:37 PM
BitchinRS's Avatar
[QOUTE]My boyfriend has all the tools but he's just having one heck of a time getting to it cuz there is a cable in the way.[/QOUTE]
Thats why I searched and searched for the the wrench. I travel about 2 - 2 and 1/2 hours one way to work everyday and and don't have time to screw around with it.
Every time I would get the timing on the mark I would to tighten up the bolt hit the wire and knock of time. With this wrench I don't end up touch the distrib or the wires. Makes it whole hell of a lot easier!!!
Do you have pics of the car??
Old Jul 19, 2003 | 07:07 AM
Erin91RS's Avatar
Car: 91 RS
Yeah, all the pictures of my car on on my cardomain website.
Erin's Camaro
Old Jul 19, 2003 | 08:40 AM
Engine: 2.8, LS1
Good luck though....
Eh, I tried!
Shadey_MF's Avatar
I took a 15mm wrench and put the boxed end into a table top vise. then i put a put a vice grip on the open end. lit up the torch and heated the the boxed end until it was red and pulled on the vise grip a bit, rinse and repeat. presto L 15mm wrench.
oh wait no, not that easy. the first "made in china" wench broke immediatly. then i took a lifetime warranty type and it worked out.
Congrats on the win
:hail:
my V6 bird lookes better than 80% of the rusted out saskatchewan f-bodies i see.
wonder if I can win something, if not a race vs. a V8
Old Jul 19, 2003 | 02:27 PM
BitchinRS's Avatar
Just incase any one is interested here's the number off the my distrib wrench. VIM V118. I'm not sure exactly who the manufacture is, but I will see if I can locate the receipt. I tend to keep just about every receipt.
Old Jul 22, 2003 | 12:26 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Congrats on the show!
Distributor hold-down bolt tools: Ratchet, 7" extension, universal (aka "Swivel"), 15mm socket. All are 3/8 inch drive.
five7kid
Northern Great Plains and Rocky Mountain
Sep 4, 2002 01:35 PM
MRZ28HO
Southern California Area
17
Aug 31, 2002 10:34 PM
Grey Goose
43
Aug 9, 2002 12:43 PM
Andy89RS
May 15, 2002 11:23 PM
GTA-Force
Pacific Northwest Region
Aug 3, 2001 01:48 PM
